# Get specific robot account
> Retrieve details about a specific robot account in an Automation Suite organization using the Identity API, including required scope and response schema.
Returns information about a robot account, based on the organization and robot account ID.
## API endpoint
`GET` `https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}/{robotAccountId}`
## Scopes
Requires the following scopes:
* `PM.RobotAccount`
* `PM.RobotAccount.Read`
## Request headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described in [Authentication methods](https://docs.uipath.com/automation-suite/automation-suite/2.2510/api-guide/authentication-methods#authentication-methods).
## Path parameters
| Parameter | Data type | Description |
| `partitionGlobalId` | String | **Required.**The ID of the organization containing the desired group. |
| `robotAccountID` | String | **Required.**The ID of the robot account you want to retrieve. |
## Responses
### 200 OK
The specified robot account information is returned, such as name, creation time, and the group IDs the account is part of.
## Example request
Let's say you gathered all the information needed to build the API call.
* Your `{baseURL}` is: `https://{yourDomain}/{organizationName}/identity_`
* Your `{access_token}` is: `1234` (for length considerations).
* The `{partitionGlobalId}` is: `3fa85f64-5717-4562-b3fc-2c963f66afa6`
* The `{robotAccountID}` is: `33-ab`
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/3fa85f64-5717-4562-b3fc-2c963f66afa6/33-ab' \
Here's the response body for a successful call:
    "id": "33-ab",
    "name": "Bot3",
    "displayName": "Bot3",
    "creationTime": "2021-10-19T14:25:01.6574988",
    "lastModificationTime": "2021-10-19T14:25:01.6574988",
    "groupIds": [
       "4d161738-7204", "ce684f6f-5af3"
