# Submit an Idea From UiPath Process Mining
> Process Mining integration with Automation Hub on Automation Suite 2023.10, enabling automation ideas to be sent directly from Process Mining to Automation Hub.
The integration with **Process Mining** enables you to send automation ideas from **Process Mining** directly to **Automation Hub**. For more details check [Sending Automation Ideas to UiPath Automation Hub](https://docs.uipath.com/process-mining/automation-cloud/latest/user-guide/sending-automation-ideas-to-uipath-automation-hub) page.
