# Platform Setup
> This is the module where the assigned System Admin sets up the organization of the platform for each Automation Hub tenant.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-148445-5c18ee04.webp)
The below options are available:
## Categories
Following the company’s profile, create a solid organizational structure to be used for all the automations and ideas that will be shared. The System Admin is responsible for configuring a structure for Automation Categories aligned with the structure of the company.
You can define and manage the [Categories](setting-up-and-managing-the-automation-categories.md) based on the specific organization set-up. Furthermore, you can choose to edit these in the web editor or download the CSV version in order to apply the edits offline and upload it back.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-149877-4b1577c7.webp)
## App Inventory
Connected with the Automation Area, this feature helps you define and manage the [IT Application Inventory](setting-up-and-managing-the-app-inventory.md). The System Admin is responsible for creating an itemized list of applications used within each Automation Area as configured in the Automation Area.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-147417-a989a3fb.webp)
## Documentation
Upload and manage company-specific document templates to be used to document the Automations in a consistent and accurate way. The [Documentation](setting-up-and-managing-the-documentation.md) repository allows you to maintain consistency across your automation efforts by organizing documentation in a uniform way. Automation Hub includes a set of pre-defined templates that allow you to standardize your documentation still you can add your own documentation according to your company's standards.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-146600-748c5f5a.webp)
## Customize Assessments
To identify suitable candidates for automation, shared ideas go through an evaluation process consisting of 2 levels of assessment:
* High Level Assessment,
* Detailed Assessment.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-148437-88384f1f.webp)
### High Level Assessment
Initiated by the **Share an Idea** button, it provides information that helps the user identify proposals that can be considered for a more detailed assessment.
After the user shares the idea by answering simple questions, the **Automation Score** is provided instantly by the platform. Check the [Information About the Idea Score](information-about-the-idea-score.md) for details about how the score is calculated.
The High Level assessment is customizable, and you can add/delete questions, reorder questions in the form, change the question type and even modify the weight of each question. For more details, please check [Customizing the High Level Assessment](hl-assessment-customization.md) page.
### Detailed Assessment
This is the stage where a detailed evaluation is performed. The Process Owner answers a predefined set of specific questions and lists the applications used in the manual process.
The **Assessment Score** highlights the Automation Potential, the Ease of Implementation, and the estimated benefit measured in annualized hours saved, in currency, and in FTEs saved per year for the considered proposal. Check the [Information About the Detailed Assessment Algorithm](information-about-the-detailed-assessment-algorithm.md) for details about how the score is calculated.
If the Detailed Assessment form does not provide all the information needed, the System Admin has the option to **customize it** by adding specific questions.
## Cost Setup
The below categories allow you to [configure the cost](setting-up-and-managing-the-cost.md) associated with the RPA implementation:
* [RPA Software Vendor](setting-up-and-managing-the-cost.md#rpa-software-vendor)
* [One Time Costs-Implementation People Costs](setting-up-and-managing-the-cost.md#one-time-costs-implementation-people-costs)
* [Running Costs-RPA Software Costs](setting-up-and-managing-the-cost.md#running-costs-rpa-software-costs)
* [Other Running Costs](setting-up-and-managing-the-cost.md#other-running-costs)
By clicking the **Currency** drop-down list, you can select the currency used to display prices and costs. This currency is applied to the entire automation program.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-148449-c3e899b7.webp)
:::note
All the costs are reflected in the **Cost Benefit Analysis** page of each Idea Profile.
## Import Pipeline
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-147073-5f17314c.webp)
## Open API
Within the **Open API** page you have access to the details that help you generate and manage the token used in order to manipulate the Automation Hub data through API calls.
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-148201-9ef08a1a.webp)
We encourage you to also review the entire **Automation Hub API Guide** as it provides all the details you need to start using the Automation Hub APIs in a fast and compelling way. The guide is built to support the **Swagger** documentation, by providing relevant and easy to follow examples.
If you prefer to work with **Postman**, a small collection is available at this [link](https://automation-hub-postman.uipath.rocks/?version=latest), which can be imported by clicking the **Run in Postman** button.
The following API requests are currently available:
* `GET` Automation Idea
* `POST` Automation Idea through the Employee-driven flow
* `POST` Automation Idea through the Coe-driven flow
* `POST` Phase and Status for Automation Idea
* `GET` Automation Pipeline
* `GET` Categories
* `GET` App Inventory
* `GET` CBA (Cost Benefit Analysis)
* `GET` Users
* `POST` Add User
* `POST` Edit User
