# Image Classification
> Image Classification out-of-the-box ML package in AI Center, a retrainable deep-learning model for classifying images into custom categories.
*Out of the Box Packages > UiPath Image Analysis > Image Classification*
This preview model is a retrainable deep learning model used to classify images. You can train it on your own data and create an ML Skill to perform image classification. This ML Package must be retrained, if deployed without training first, deployment will fail with an error stating that the model is not trained.
This model is not available for offline installations.
## Model details
### Input type
FILE
### Input description
Full path of the image file on which you want to classify.
Make sure that the image format is either JPEG or PNG.
### Output description
JSON with identified label for the image and confidence score (between 0-1).
  "response": {
    "label": "car",
    "confidence": 0.85657345056533813
### Recommend GPU
By default, a GPU is recommended.
### Training enabled
By default, training is enabled.
## Pipelines
All three types of pipelines (Full Training, Training, and Evaluation) are supported by this package. For most use cases, no parameters need to be specified, the model is using advanced techniques to find a performant model. In subsequent trainings after the first, the model uses incremental learning (that is, the previously trained version will be used, at the end of a Training Run).
### Dataset format
For training and evaluation datasets, point to a folder with a subfolder called `images` and this subfolder can contain input several folders with different classes (for example, a folder called `cats` with pictures of cats, and another one called `dogs` with pictures of dogs, and so on).
Example:
-- <Training / Evaluation Directory>
   -- images
      -- Bus
      -- Truck
      -- Car
### Environment variables
* **Epochs** - default value `20`
### Artifacts
#### Classification report
precision    recall  f1-score   support
    Positive       0.75      0.90      0.82        10
    Negative       0.88      0.70      0.78        10
    accuracy                           0.80        20
   macro avg       0.81      0.80      0.80        20
weighted avg       0.81      0.80      0.80        20
#### Confusion matrix
![Example of a confusion matrix.](https://dev-assets.cms.uipath.com/assets/images/ai-center/ai-center-example-of-a-confusion-matrix-107438-4f452938-a0dece1b.webp)
#### Predictions.csv
This is a CSV file with predictions on the test set used for evaluation.
filename      actual        predicted
38    00043.jpg    Positive    Positive
17    00001.jpg    Positive    Positive
59    00014.jpg    Negative    Positive
31    00015.jpg    Positive    Positive
15    00008.jpg    Positive    Positive
69    00025.jpg    Negative    Negative
49    00003.jpg    Positive    Positive
5      00034.jpg    Positive    Positive
36    00044.jpg    Positive    Positive
50    00042.jpg    Negative    Positive
96    00011.jpg    Negative    Negative
53    00046.jpg    Negative    Positive
94    00036.jpg    Negative    Negative
