# About Projects
> Isolated resource groups in AI Center for organizing datasets, packages, pipelines, ML skills, and logs for a specific ML solution.
A Project is an isolated group of resources (datasets, pipelines, packages, skills, and logs) you may use to enable building a specific ML solution. It is recommended that you organize each project to correspond to one business automation.
The **Projects** page, the first page displayed when accessing **UiPath® AI Center**, contains your list of available projects. Each project is represented by a card, showing top-level information about the project:
* Project name
* Description
* Active Pipelines - the number of currently running or scheduled pipelines
* Deployed Packages - the number of packages belonging to this project that have been deployed as ML skills.
Moreover, you can create new projects, and edit or delete existing ones.
  ![Screenshot including the Projects page in UiPath AI Center.](https://dev-assets.cms.uipath.com/assets/images/ai-center/ai-center-screenshot-including-the-projects-page-in-uipath-ai-center-450435-4f297bf8-6b56dccb.webp)
## Project dashboard
A high-level view of the entities grouped within a specific project (datasets, packages, pipelines) is presented in the **Dashboard** page. This is where you can find information about the user who created the project, its creation time, and its description. Select a card in the **Projects** page to navigate to the **Dashboard**.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/ai-center/ai-center-docs-image-450440-35292703-1b8a45ea.webp)
