# Forward Task
> ForwardTask activity that forwards an Action Center task to a specified user.
`UiPath.Persistence.Activities.Tasks.ForwardTask`
## Description
Forwards the specified action to the specified user.
## Project compatibility
**Windows - Legacy** | **Windows** | **Cross-platform**
## Windows, Windows - Legacy configuration
### Designer panel
* **TaskId** - The ID of the Action you want to forward. This field supports integer values only.
* **User Name or Email** - The user name or the email of the user you want to forward the Action to. This field supports string values only.
### Properties panel
#### Common
* **ContinueOnError** - Specifies if the automation should continue even when the activity throws an error. This field supports Boolean values (True, False) only. The default value is False. As a result, if the field is blank and an error is thrown, the execution of the project stops. If the value is set to True, the execution of the project continues regardless of any error.
:::note
If this activity is included in **Try Catch** and the value of the **ContinueOnError** property is True, no error is caught when the project is executed.
* **DisplayName** - The display name of the activity.
* **TimeoutMS** - Specifies the amount of time (in milliseconds) to wait for the activity to run before an error is thrown. The default value is 30000 milliseconds (30 seconds).
#### Input
* **Comments** - The comments regarding the action forwarding. This field supports string values only.
* **Orchestrator Folder Path** - The path to the Orchestrator Folder you want to use with this activity. If left empty, the current Orchestrator folder is used. This field supports strings and String variables only.
:::note
If the user performing this action does not have the required permissions for the target folder, task forwarding fails and throws a critical error. You can view more info on Folder Permissions [here](https://docs.uipath.com/orchestrator/docs/about-folders#section-roles-and-permissions-for-folders).
#### Misc
* **Private** - If selected, the values of variables and arguments are no longer logged at Verbose level.
## Cross-platform configuration
### Advanced options
#### Common
:::note
#### Input
:::note
