# Access control
> Folder-based access control in Action Center, including folder-based user visibility and permissions, and action redirection to specific folders.
[Orchestrator modern folders](https://docs.uipath.com/orchestrator/automation-suite/2.2510/user-guide/managing-folders) help you containerize actions, processes, and users.
By default, Actions are created inside the same folder as the process that generated them. Only the users added inside that folder can access the Actions, based on their roles and permissions, as follows:
* Multiple users can see the **Unassigned** Actions in the specified folder.
* An [Action User](https://docs.uipath.com/action-center/automation-suite/2.2510/user-guide/roles-and-permissions#custom-roles---actions) sees their assigned actions (inside the **Pending** tab) only.
:::note
As soon as an Action is assigned to a user, it moves from the **Unassigned** tab to the **Pending** tab of the assigned user.
* An [Action Admin](https://docs.uipath.com/action-center/automation-suite/2.2510/user-guide/roles-and-permissions#custom-roles---actions) sees all **Pending** Actions and has the option to reassign them to other users, if needed.
## Redirecting actions to specific folders
To control which users can access specific Actions, through the use of folders:
1. [Create a folder](https://docs.uipath.com/orchestrator/v2022.10/docs/managing-folders#creating-folders).
2. Make sure the users or groups that need to access the Actions are [assigned to the folder](https://docs.uipath.com/orchestrator/v2022.10/docs/managing-folders#giving-folder-access-to-accounts-or-groups).
3. Inside your workflow in Studio, use the **Orchestrator Folder Path** property to redirect the Action creation or assignment to the desired folder.
:::note
Find the **Orchestrator Folder Path** property in activities such as **Create Form Task** and **Assign Task**.
![docs image](https://dev-assets.cms.uipath.com/assets/images/action-center/action-center-docs-image-100388-5545c0b4-117c7062.webp)
Redirecting an Action assignment (from the **Assign Task** activity) or creation (from the **Create Form Task** activity) to a different folder allows you to control who can access the Actions, as you can add or remove specific users from the folder.
:::tip
For a more granular user restriction, assign them specific [roles and permissions](https://docs.uipath.com/action-center/automation-suite/2.2510/user-guide/roles-and-permissions#custom-roles---actions) inside the desired folder.
