# Deploy UiPathDocumentOCR
> Create a **UiPathDocumentOCR** ML package in AI Center.
For online installation, the **UiPathDocumentOCR** model is already included in the **Out of the box packages** section.
For offline instalation, follow the steps included in the [Upload model to AI Center section](https://docs.uipath.com/ai-center/automation-suite/2024.10/user-guide/ml-packages-offline-installation#upload-model-to-ai-center).
Go to **ML Packages** > **Out of the box packages** > **UiPath Document Understanding** > **UiPathDocumentOCR**, and select **Submit**.
Go to ML Skills and create a new ML skill for the **UiPathDocumentOCR** package you created.
Please use **Advanced Infra Settings** to update the deployment to update the replica (the number of replica should ideally be equal to the number of nodes) and maximize the CPU (at least 4) and RAM requests if you are not using GPU machines, or the **UiPathDocumentOCR** processing will be slow and may fail.
The OCR engine needs GPU for optimal performance, and it is recommended for production workloads. However, if GPU is not available, it can still run on CPU, but it requires higher resources than the default. Advanced infra settings should be adjusted as such:
**Replicas**: increase if there is concurrent usage of UiPathDocumentOCR. If you are using UiPathDocumentOCR to do imports on a single Data Labeling session at a time and the UiPathDocumentOCR is not used in other UiPath® workflows then 1 replica suffices. Otherwise, the number of replicas needs to be increased. There is no "magic" number here, you need some trial and error. Do not use more than 2 replicas on a single node installation. Ideally, replica count should equal the number of nodes in the cluster (1 replica/node). If more parallelism is needed, increasing the CPU helps
**CPU**: it should be at least 4 (for each replica). Make sure you have appropriate resources. There is no "magic" number, but more CPU means faster processing time. You need to test under your specific scenarios what is enough.
It can take up to 30 minutes for the ML Skill to be ready. You may need to refresh the AI Center page for the status to change. Once the ML Skill is available, select the ML Skill and go to **Modify current deployment**.
Switch the toggle on to make the ML Skill public. You may need to wait for a few minutes and refresh the page.
Select the ML Skill and copy the URL, which is the endpoint of the **UiPathDocumentOCR** for later use.
![Screenshot of the ML Skills interface.](https://dev-assets.cms.uipath.com/assets/images/document-understanding/document-understanding-screenshot-of-the-ml-skills-interface-465677-63e0aa78-f054a3eb.webp)
