# Menu Compliance
> Purchase-to-Pay Compliance menu dashboard in Process Mining on Automation Suite: information for assessing process compliance against standards and requirements.
The dashboards of the **Compliance** menu contain information that will help determine whether the process complies with specified requirements or standards.
The **Compliance** menu has the following dashboard:
1. [Compliance - Maverick buying](https://docs.uipath.com/process-mining/automation-suite/2024.10/user-guide/p2p-menu-compliance#compliance---maverick-buying) - the dashboard where you can find purchase order items that were processed outside the regular Purchase-to-Pay process.
2. [Tag Details](https://docs.uipath.com/process-mining/automation-suite/2024.10/user-guide/p2p-menu-compliance#tag-details) - the dashboard where you can find detailed information on Maverick buying tags.
## Compliance - Maverick buying
### Compliance - Maverick buying
The **Compliance** menu contains the **Maverick buying** dashboard. Maverick buying is defined as the number of purchase order items that were processed outside the regular Purchase-to-Pay process without involvement of the Procurement department.
**Compliance - Maverick buying** is the dashboard where you can analyze your process regarding maverick buying. It enables you to analyze purchase order items labeled with one or more maverick buying tag.
:::note
Purchase order items of purchase orders that were created within the selected period are displayed.
### KPIs
The following table describes the KPIs displayed at the top of the **Conformance - Maverick buying** dashboard.
| KPI | Description |
| Maverick buying value | Total value of the purchase order items involved in maverick buying. |
| Percentage maverick buying | The percentage of purchase order items that were processed outside the regular Purchase-to-Pay process. |
| Number of items | The number of purchase order items that were processed outside the regular Purchase-to-Pay process. |
| Total PO items | The total number of purchase order items. |
### Maverick buying tags
The following table describes the predefined tags for maverick buying.
| Tag | Indicates that the... |
| Goods received before PO item creation | goods were received before a purchase order item was created. |
| Goods received before PO approval | goods were received before a purchase order was approved. |
| Goods received without PO approval | goods were received for a purchase order that was not approved. |
| Invoice received before PO item creation | invoice was received before a purchase order item was created. |
| Invoice received before PO approval | invoice was received before a purchase order was approved. |
| Invoice received before goods received | invoice item was created before the last goods received event for a purchase order item occured. |
| Invoice received before PR creation | invoice item was created before the create purchase requisition event occured. |
| Invoice received without PO approval | invoice was received for a purchase order that was not approved. |
| Unreasonably quick goods delivery | goods were delivered within 2 hours after the purchase order was approved. |
| Unreasonably quick invoice received | invoice was received within 2 hours after the purchase order was approved. |
### Metrics
You can create various different contexts by selecting different categories from the drop-down list.
The following table describes the metrics that can be used to analyze the purchase items regarding the selected category.
| Metric | Description | Base |
| Number of items | The number of unique purchase order items that are processed outside the regular Purchase-to-Pay process, i.e. have a maverick buying tag. | Purchase order items |
| Percentage of items | The percentage of purchase order items that are processed outside the regular Purchase-to-Pay process, i.e. have a maverick buying tag. | Purchase order items |
| Avg. item value | The average value of the purchase order items that are processed outside the regular Purchase-to-Pay process, i.e. have a maverick buying tag. | Purchase order items |
| Total item value | Sum of the value of the purchase order items that are processed outside the regular Purchase-to-Pay process, i.e. have a maverick buying tag. | Purchase order items |
### Maverick Buying Process
The process graph displays the process for purchase order items regarding maverick buying.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-364579-be5d6758-75ec65a8.webp)
:::note
Purchase order items that do not have a Maverick buying tag are taken into account. When the number displayed on an edge is `0`, this means there are no purchase order items that have a Maverick buying tag.
You can select a different metric from the activity and edge metrics selector to display the process graph based on different metrics. BThe following tables describe the available metrics.
#### Activity metrics
| Number of items | The number of unique cases. | Purchase order items |
| Number of items | The number of unique purchase order items that have a maverick buying tag, within the selected period. | Maverick buying |
:::note
You can use the **Detail** slider to change the number of activities and/or edges shown. Check out [Working with process graphs](https://docs.uipath.com/process-mining/automation-suite/2024.10/user-guide/working-with-process-graphs#working-with-process-graphs).
#### Edge metrics
| Number of items | The number of unique purchase order items. | Purchase order items |
| Average throughput time | The average throughput time between the activities. | Duration |
## Tag Details
The **Tag details** dashboard displays a list of all Maverick buying tags, within a selected period, and their properties.
Each row represents a tag related to a certain purchase order item. It provides detailed information on the event level.
