# System requirements
> System requirements for the Process Mining server used with DataBridgeAgent to load data in Process Mining on Automation Suite.
## Introduction
Using **DataBridgeAgent** requires a **Process Mining** server installation. This page gives an overview of the system requirements for the **Process Mining** server on which you want to use **DataBridgeAgent** to load data for **Process Mining**.
:::important
If you want to install **Process Mining** or any of its components, you need access to an environment, and you need a **Process Mining** license. Please consult your **Process Mining** contact. **DataBridgeAgent** does not require a separate license.
### Server OS
**Process Mining** is a 64-bit program and requires a 64-bit environment. For production systems the following operating systems are supported:
* Windows 10
* Windows Server 2019
* Windows Server 2016
* Windows Server 2012 R2
  :::note
  For an installation that is solely used for loading data with **DataBridgeAgent** to **Process Mining**, Windows 10 suffices.
### Minimum system requirements
The following table describes the minimum system requirements:
| Component | Minimal size | Description |
| CPU | 1 core | Strong single-core performance is recommended. |
| Memory | 32 GB |  |
| Storage | *variable* | The disk needs to be large enough for the operating system, **Process Mining**, the data, and cache files. **DataBridgeAgent** uses less than 1GB. |
:::note
The requirements only apply to a **Process Mining** server that is solely used for loading data with **DataBridgeAgent** to **Process Mining Automation Suite**. See [Hardware and software requirements](https://docs.uipath.com/process-mining/standalone/2021.10/user-guide/process-mining-hardware-and-software-requirements) for a complete overview of the requirements for a Process Mining on-premises installation.
