# Order-to-Cash input fields
> Input field reference for the Order-to-Cash app template on Automation Suite, listing fields, data types, and mandatory status for each input table object.
## Introduction
This section contains an overview of the fields for each of the input tables of **Order-to-Cash**. For each object the fields are listed. For each field, the name and a data type are displayed. Apart from that, it is indicated whether the field is mandatory if the object is included in the Order-to-Cash process.
:::note
Optional tables should be part of the input, but may contain no records. When a field is mandatory, it should not contain `NULL` values.
| Object | Tables | Mandatory Y/N |
| Sales order | `Sales_orders`  `Sales_order_items` | Y |
| Deliveries | `Deliveries`  `Delivery_items` | N |
| Invoice | `Invoices`  `Invoice_items`  `Invoide_cancellations` | N |
| Accounting | `Accounting_documents` | N |
| Payment | `Payments` | N |
| Events* | `Event` | Y |
*) **Events** is not an object of the Order-to-Cash process, but an events table is mandatory for a correct working of the Order-to-Cash process app.
The following illustration shows the relations between objects of **Order-to-Cash**.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-docs-image-54660-1c67f865-e77dd4a0.webp)
:::important
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names (in English) in the following tables and that the file names match the table names.
### Field types
The following table describes the different field types and their default format settings.
| Field type | Format |
| boolean | `true`, `false`, `1`, `0` |
| date | `yyyy-mm-dd` |
| datetime | `yyyy-mm-dd hh:mm:ss[.ms]`, where `[.ms]` is optional.  Refer to the [official Microsoft documentation](https://support.microsoft.com/en-us/office/format-a-date-the-way-you-want-8e10019e-d5d8-47a1-ba95-db95123d273e#:~:text=what%20you%20want.-,Select%20the%20cells%20you%20want%20to%20format.,format%20you%20want%20in%20Type) if you want to change the date format. |
| double | Decimal separator: `.` (dot)  Thousand separator: none |
| integer | Thousand separator: none |
| text | N/A |
## Sales order
### Sales_orders_base_raw
The following table describes the fields of the `Sales_orders_base_raw` table.
| Name | Type | Mandatory Y/N | Description |
| `Sales_order_ID` | text | Y | The unique identifier of the sales order. |
| `Company` | text | N | The company for which the sales order is created. |
| `Customer` | text | N | The customer for whom the sales order is created. |
| `Customer_country` | text | N | The country associated to the customer. |
| `Customer_region` | text | N | The region associated to the customer. |
| `Distribution_channel` | text | N | The distribution channel associated to the sales order. |
| `Division` | text | N | The division associated to the sales order. |
| `Requested_delivery_date` | date | N | The customer’s requested delivery date for the sales order. |
| `Sales_group` | text | N | The sales group associated to the sales order. |
| `Sales_office` | text | N | The sales office associated to the sales order. |
| `Sales_order_creator` | text | N |  |
| `Sales_order_type` | text | N | The sales order type of the sales order. |
| `Sales_organization` | text | N | The sales organization of the sales order. |
### Sales_order_items_base_raw
The following table describes the fields of the `Sales_order_items_base_raw` table.
| `Sales_order_item_ID` | text | Y | The unique identifier of the sales order item. |
| `Sales_order_ID` | text | N | The unique identifier of the sales order. |
| `Category` | text | N | The category of sales order item. |
| `Creation_date` | date | N | The date on which the sales order item is created. |
| `Incoterms` | text | N | The incoterms associated to the sales order item. |
| `Latest_expected_delivery_date` | date | N | The latest expected delivery date of (parts of) the sales order item. |
| `Material` | text | N | The material sold. |
| `Material_group` | text | N | The categorization of the material sold. |
| `Payment_terms` | text | N | The terms of payment associated to the sales order item. |
| `Plant` | text | N | The plant associated to the sales order item. |
| `Profit_center` | text | N | The profit center associated to the sales order item. |
| `Quantity` | text | N | The quantity and unit of measurement sold. |
| `Sales_order_item` | text | N | A user-friendly name to identify the sales order item |
| `Sales_order_item_creator` | text | N |  |
| `Shipping_point_country` | text | N | The country where the goods are delivered associated to the sales order item. |
| `Storage_location` | text | N | Storage location associated to the sales order item. |
| `Value` | double | N | A monetary value related to the sales order item. |
## Delivery
### Deliveries_base_raw
The following table describesthe fields of the `Deliveries_base_raw` table.
| `Delivery_ID` | text | Y | The unique identifier of the delivery. |
| `Company` | text | N |  |
| `Delivery_creator` | text | N |  |
| `Delivery_date` | date | N |  |
| `Delivery_type` | text | N |  |
| `Incoterms` | text | N |  |
| `Planned_delivery_date` | date | N |  |
| `Sales_organization` | text | N |  |
| `Shipping_conditions` | text | N |  |
| `Staging_area` | text | N |  |
| `Warehouse_number` | text | N |  |
### Delivery_items_base_raw
The following table describes the fields of the `Delivery_items_base_raw` table.
| `Delivery_item_ID` | text | Y | The unique identifier of the delivery item. |
| `Delivery_ID` | text | N* | The unique identifier of the delivery. |
| `Sales_order_item_ID` | text | N* | The unique identifier of the sales order item. |
| `Delivery_item_creator` | text | N |  |
| `Category` | text | N |  |
| `Delivery_item_is_invoiced` | boolean | N | Indicates if the sales order item is released to invoicing. |
| `Delivered_quantity` | text | N |  |
| `Material` | text | N |  |
| `Material_group` | text | N |  |
| `Plant` | text | N |  |
| `Storage_location` | text | N |  |
| `Value` | double | N |  |
* If you want to include events related to other objects than the sales order in the process graphs, the `Delivery_ID` and `Sales_order_item_ID` fields are mandatory.
## Invoice
### Invoices_base_raw
The following table describes the fields of the `Invoices_base_raw` table.
| `Invoice_ID` | text | Y | The unique identifier of the invoice. |
| `Baseline_date` | date | N |  |
| `Discount` | double | N |  |
| `Discount_percentage_1` | double | N |  |
| `Discount_percentage_2` | double | N |  |
| `Discount_period_1` | integer | N |  |
| `Discount_period_2` | integer | N |  |
| `Fiscal_year` | text | N |  |
| `Invoice_creator` | text | N |  |
| `Invoice_date` | date | N |  |
| `Invoice_type` | text | N |  |
| `Net_payment_period` | integer | N | Net payment period of the invoice in days. |
| `Payment_method` | text | N |  |
| `Payment_terms` | text | N |  |
| `Posting_date` | date | N |  |
### Invoice_items_base_raw
The following table describes the fields of the `Invoice_items_base_raw` table.
| `Invoice_item_ID` | text | Y | The unique identifier of the invoice item. |
| `Delivery_item_ID` | text | N* | The unique identifier of the delivery item. |
| `Invoice_ID` | text | N* | The unique identifier of the invoice. |
| `Invoice_item_creator` | text | N |  |
| `Invoice_item_is_cancelled` | boolean | N | Indicates if the invoice item is cancelled. |
| `Invoice_item_is_released_into_accounting` | boolean | N | Indicates if the invoice item is billable. |
| `Invoiced_quantity` | text | N |  |
* If you want to include events related to other objects than the sales order in the process graphs, the `Invoice_ID` and `Delivery_item_ID` fields are mandatory.
### Invoice_cancellations_base_raw
The following table describes the fields of the `Invoice_cancellations_base_raw` table.
| `Invoice_cancellation_ID` | text | Y | The unique identifier of the invoice cancellation. |
| `Invoice_ID` | text | N* | The unique identifier of the invoice that is cancelled. |
| `Invoice_cancellation_creator` | text | N |  |
* If you want to include events related to other objects than the sales order in the process graphs, the `Invoice_ID` field is mandatory.
## Accounting
### Accounting_documents_base_raw
The following table describes the fields of the `Accounting_documents_base_raw` table.
| `Accounting_document_ID` | text | Y | The unique identifier of the accounting document. |
| `Accounting_document_creator` | text | N |  |
| `Accounting_document_is _cancelled` | boolean | N | Indicates if the accounting document is cancelled. |
| `Accounting_document_is _cleared` | boolean | N | Indicates if the accounting document has been handled and is closed. |
| `Document_date` | date | N |  |
| `Document_type` | text | N |  |
| `Net_payment_period` | integer | N |  |
| `Payment_date` | date | N |  |
| `Payment_status` | text | N |  |
| `Transaction_type` | text | N |  |
## Payment
### Payments_base_raw
The following table describes the fields of the `Payments_base_raw` table.
| `Payment_ID` | text | Y | The unique identifier of the payment. |
| `Accounting_document_ID` | text | N* | The unique identifier of the accounting document. |
| `Payment_creator` | text | N |  |
| `Payment_is_complete` | boolean | N |  |
| `Payment_is_debit` | boolean | N |  |
* If you want to include events related to other objects than the sales order in the process graphs, the `Accounting_document_ID` field is mandatory.
## Events
### Events
The `Events` table contains all sub-event logs for all objects. The following table describes the fields of the `Events` table.
| `Activity` | text | Y | The name of the event. This describes the step in the process. |
| `Event_end` | datetime | Y | The timestamp associated with the end of executing the event . |
| `Activity_category` | text | N | The type of activity that takes place (e.g. change, set/remove block) |
| `Activity_order` | integer | N | The number that defines in which order activities are executed in case they have the same **Event end**. |
| `Activity_trigger` | text | N | Field describing the reason for the executed activity |
| `Automated` | boolean | N | Indicator whether the event is manually executed or automated. |
| `Department` | text | N | The department that executed the event |
| `Event_detail` | text | N | Information related to the event. |
| `User` | text | N | The user who executed the event. |
| `User_function` | text | N | The function associated with the user. |
| `User_type` | text | N | The categorization of the user. |
| `Event_cost` | double | N | The costs of executing the event. |
| `Event_start` * | datetime | N | The timestamp associated with the start of executing the event. |
| `Event_processing_time` | integer | N | The time for executing the event (in milliseconds). |
If both `Event_start` and `Event _end` are defined in your dataset, the duration of the event is known. This will be used to calculate the *throughput time* of events. If only `Event_end` end is defined, the *throughput time* will be calculated as the difference between previous `Event_end` and the `Event_end`. `Event_start` is only taken into account if every record in the dataset contains a *not-null* value.
:::note
It is expected that for each record exactly one of the `ID` fields is filled in, which is the one of the object on which the event takes place. The other `ID` fields may be empty. Next to the standard mandatory fields (`Activity` and `Event_end`), one object `ID` is mandatory. This field depends on the object the event is part of.
