industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Sales dataset
Sales dataset containing aggregated daily sales per product and location, an optional demand-history signal for Inventory Management.
The sales dataset contains aggregated daily sales for each product at each location. It is an optional alternative or complement to the Customer orders dataset as a demand-history signal.
Purpose​
The inventory management solution uses aggregated sales data to understand historical demand at the product and location level. This dataset can be provided instead of, or in addition to, the Customer orders dataset when order-line level data is not available or when aggregated demand history is preferred.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringPrimary key
location_idUnique identifier for the store or distribution centre.stringPrimary key
day_dateDate corresponding to the reported sales.datePrimary key
sales_unitsNumber of units sold for the given product, location, and date.floatNon-null
sales_valueRevenue value of the units sold. Should correspond to the value of sales_units.floatNon-null
Usage notes​
  • This dataset is an optional alternative or complement to the Customer orders dataset.
  • A daily record of sales is recommended to support accurate demand analysis.
  • Product and location identifiers must align with the corresponding Products and Locations datasets.
  • Sales quantities should use the same unit of measure as related datasets.
  • Purpose​
  • Required fields​
  • Usage notes​
Verbinden
Benötigen Sie Hilfe? Support
