industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Transfer order dataset
Transfers dataset containing details of inventory transfers between internal locations, used by Rebuy & Replenishment to represent internal stock movements.
The transfers dataset contains details of inventory transfers between internal locations, such as distribution centres and stores. It represents internal stock movements used to replenish inventory within the customer's supply chain.
This dataset is optional if internal transfers are already captured in the purchase orders dataset. When provided separately, it enables the Rebuy & Replenishment capability to more accurately project future inventory levels across locations.
Purpose​
The Rebuy & Replenishment capability uses the transfers dataset to:
  • Track internal inventory movements between locations
  • Project future stock availability based on expected transfers
  • Evaluate how internal supply flows affect inventory positions and replenishment decisions
This dataset complements external purchase order data by representing internal supply movements.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringPrimary key
location_idIdentifier for the destination store or distribution centre.stringPrimary key
order_numberUnique identifier for each transfer order.stringPrimary key
source_idIdentifier for the supplying location or distribution centre.stringNon-null
ordered_atDate and time (UTC) when the transfer order was placed.datetimeNon-null
ordered_unitsNumber of units ordered for the transfer line item.floatNon-null
expected_departure_dateDate and time (UTC) when the transfer is expected to leave the source location.datetimeNon-null
actual_departure_dateDate and time (UTC) when the transfer actually left the source location.datetimeNullable
expected_delivery_dateDate and time (UTC) when the transfer is expected to arrive at the destination.datetimeNon-null
actual_delivery_dateDate and time (UTC) when the transfer arrived at the destination.datetimeNullable
delivered_unitsNumber of units delivered for the transfer line item.floatNullable
statusStatus of the transfer line item (for example, Open, Pending approval, Closed).stringNullable
Usage notes​
  • Transfers should be provided at line-item level to support accurate inventory projections.
  • Both planned and completed transfers should be included to preserve historical context.
  • Partial transfers should be reflected using delivered quantities and actual delivery dates.
  • Identifiers (product_id, location_id, source_id) must align with the corresponding Products and Locations datasets.
  • Units of measure must be consistent across transfers, stock, and demand datasets.
  • Purpose​
  • Required fields​
  • Usage notes​
Verbinden
Benötigen Sie Hilfe? Support
