industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Order parameters dataset
Order parameters dataset containing planning configuration per product, location, and supplier combination, used by Inventory Management for replenishment recommendations.
The order parameters dataset contains planning configuration data for each product, location, and supplier combination. It defines the timing and service assumptions used by the inventory management solution when calculating inventory parameters and replenishment recommendations.
This dataset plays a critical role in determining how inventory decisions are evaluated over time.
Purpose​
The solution uses the order parameters dataset to:
  • Understand how frequently inventory is reviewed and replenished
  • Calculate the ordering cycle (also known as the risk period)
  • Evaluate demand volatility over lead times and review periods
  • Support accurate safety stock and replenishment calculations
During presales, this dataset is also used to validate planning assumptions and assess potential inventory improvements.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringPrimary key
location_idIdentifier for the store or distribution centre where the product is delivered.stringPrimary key
source_idIdentifier for the supplier or internal distribution centre. Can represent an external supplier or an internal source.stringNon-null
review_period_daysNumber of days between reviewing purchase orders. May be determined during scoping.intNon-null
service_levelTarget service level for the product, expressed as a value between 0 and 1. May be determined during scoping.floatNon-null
lead_time_daysNumber of days between placing an order and receiving the product.intNon-null
minimum_guardrailMinimum inventory guardrail quantity applied when generating replenishment recommendations.intNullable
Usage notes​
  • The ordering cycle for a product is calculated as the sum of the lead_time_days and review_period_days.
  • If review_period_days or service_level values are not provided, they may be defined during onboarding or scoping.
  • Identifiers (product_id, location_id, source_id) must align with the corresponding Products, Locations, and Suppliers datasets.
  • This dataset typically changes less frequently than demand or stock data but is critical to planning accuracy.
  • Purpose​
  • Required fields​
  • Usage notes​
Verbinden
Benötigen Sie Hilfe? Support
