industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Tax dataset
Tax dataset for the Markdown & Promotions module, holding VAT rates per product and location.
The Tax dataset holds VAT rates for each product at each location. It provides the tax context used to compute net values in markdown and promotion analysis.
Purpose​
The Markdown & Promotions module uses the Tax dataset to:
  • Provide VAT rates by product and location
  • Support accurate net value and margin calculations
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
created_atTimestamp when the record was created.timestampPrimary key
location_idUnique identifier for the store or location.stringPrimary key
Foreign key to location
product_idUnique identifier for the product SKU.stringPrimary key
Foreign key to product
updated_atTimestamp when the record was last updated.timestampNullable
vatVAT rate applied to the product at the location.floatNullable
Usage notes​
  • Product and location identifiers must align with the Products and Locations datasets.
  • Rates should reflect the tax applicable at the associated location.
Why this dataset matters​
Accurate tax rates ensure value and margin calculations reflect net figures, which matters for discount-depth and margin guardrails.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
Verbinden
Benötigen Sie Hilfe? Support
