industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Schema lifecycle
Manage the schema lifecycle in the Supply Chain & Retail Solutions Data Ingestion API, including saving, rolling out, upgrading, adding columns, and inspecting tenant schemas.
This page covers the schema-management endpoints: saving a standard schema for an application, rolling it out for a tenant solution, upgrading to a new version, adding a new column, and inspecting what is currently rolled out. Use it together with Getting Started and the API Guide.
All schema endpoints are rooted at https://ingestion.peak.ai/api/v2/schema.
Lifecycle overview​
A schema goes through three stages:
  1. Save the standard schema for an application (one-time per appName + appVersion).
  2. Roll out that standard schema for a specific tenant solution. This creates the warehouse tables (and a matching <table_name>_failed_rows table for each) and records a tenant-scoped schema entry.
  3. Evolve the rolled-out schema over time — by upgrading to a new app version or by adding a new column to an existing table.
You can inspect what's been rolled out at any time using the list and get endpoints.
Save a standard schema​
Saves an application-level standard schema that can later be rolled out to one or more tenant solutions. Each appName + appVersion combination must be unique.
POST https://ingestion.peak.ai/api/v2/schema
Payload​
FieldRequiredDescription
appNameYesApplication identifier the schema belongs to (e.g., quote-pricing)
appVersionYesSemantic version of the schema (e.g., 1.0.0)
schemaDefinitionYesSchema specification as a JSON string. See Schema definition structure below for what goes inside it.
schemaSynergyTagNoOptional tag used by downstream metric publishing
dryRunNoWhen true, validates the payload without persisting. Returns 200 OK instead of 201 Created. Default false.
Schema definition structure​
schemaDefinition is a JSON-encoded array of table definitions. Each table has columns, and each column declares its data type and a list of validations.
Per-table fields:
tableNameYesTable name. Must match ^[A-Za-z_][A-Za-z0-9_]*$.
columnsYesNon-empty array of column definitions (see below).
primaryKeysNoArray of column names that form the primary key.
uniqueKeysNoArray of arrays; each inner array is a set of column names that must be unique together.
foreignKeysNoArray of foreign-key definitions, each with referencedTable, columnMappings, and an optional constraintName.
skipValidationsNoWhen true, runtime validation is skipped for this table. Default false.
scheduleConfigNoPer-table scheduled-ingestion configuration. See Scheduled ingestion.
objectValidationsNoArray of object-level validation rules — asynchronous data-quality checks and constraint toggles. See Object-level validations.
Per-column fields:
columnNameYesColumn name. Must match ^[A-Za-z_][A-Za-z0-9_]*$.
dataTypeYesOne of boolean, date, float, integer, json, numeric, string, timestamp. See Data Types.
validationsYesNon-empty array of validation rules — at least one entry per column (see below).
validations[].typeYesThe rule for each entry. One of required, optional, nonNull, minLength, maxLength, range, enum, timestampFormat. Every column must include exactly one of required or optional.
precisionConditionalRequired when dataType is numeric (1–38). Rejected when dataType is float. Ignored for other types.
scaleConditionalRequired when dataType is numeric (0–37). Rejected when dataType is float. Ignored for other types.
defaultValueNoDefault value applied when the column is added to existing rows via schema upgrade or add-column.
Validation rules — what to include in validations[]:
Every entry in a column's validations array is a { "type": "<rule>", ... } object. The validations array is required and must not be empty: every column has to state its required-ness explicitly.
Required vs optional columns. Every column must declare exactly one of these two markers:
  • { "type": "required" } — the column's key must be present in every ingest payload. Submitting a row without it fails with DI_E_23N01.
  • { "type": "optional" } — callers can leave the key out, and the column is stored as NULL — or its defaultValue, if one is set.
A column that declares neither marker, declares both, or supplies an empty validations array is rejected at save-schema with 400 Bad Request. Two further constraints apply:
  • Primary-key columns must be required and cannot be optional. Declaring a primary-key column as optional (or without required) returns 400 Bad Request.
  • nonNull may only be used together with required — a nonNull + optional column is rejected with 400 Bad Request. To make a column optional but never stored as null, set a defaultValue instead of using nonNull.
One rule is always enforced regardless of required-ness: every date or timestamp column must include { "type": "timestampFormat", "format": "<format>" }, where format is one of:
  • YYYY-MM-DD — for date
  • YYYY-MM-DD HH:MI:SS — for timestamp (no timezone)
  • YYYY-MM-DD HH:MI:SS ±hh:mm — for timestamp (with timezone)
All other validation types are optional — include them only where you want their effect. To turn one off, just leave it out of the validations array; there is no per-validator enabled: false flag.
TypeParametersEffect when included
nonNullnoneValue cannot be null or blank. (required controls key presence; nonNull controls the value.)
minLengthvalue (integer)Minimum string length.
maxLengthvalue (integer)Maximum string length.
rangemin, max (numbers)Numeric value must fall within the inclusive range.
enumvalue (array)Value must be one of the listed options.
Required-ness and nullability
A column's required-ness is set by its required/optional marker, and nonNull controls whether the value may be null: required/optional control whether the key must be present in the payload, nonNull controls the value. Choose the combination that matches how the column should behave:
You wantMarkerInclude nonNull?
Key must be present, value cannot be nullrequiredYes
Key must be present, value can be nullrequiredNo
Key may be omitted; stored as null (or defaultValue) when absentoptionalNo
The nonNull-with-optional (or nonNull without required) combination is rejected — to make a column optional but never stored as null, give it a defaultValue instead of nonNull. Primary-key columns must always be required.
The per-table pages in the API Guide reflect these flags as the Required and Nullable columns of each attribute table.
You can also add a column after rollout through the add-column endpoint — useful when a new optional column is needed on an already-rolled-out table; existing rows are backfilled with the supplied defaultValue.
Example column definitions:
"columns": [
  { "columnName": "order_id", "dataType": "string",
    "validations": [{ "type": "required" }, { "type": "nonNull" }] },
  { "columnName": "amount", "dataType": "numeric", "precision": 10, "scale": 2,
    "validations": [{ "type": "required" }, { "type": "nonNull" }, { "type": "range", "min": 0, "max": 1000000 }] },
  { "columnName": "placed_at", "dataType": "timestamp",
    "validations": [{ "type": "required" }, { "type": "nonNull" }, { "type": "timestampFormat", "format": "YYYY-MM-DD HH:MI:SS" }] },
  { "columnName": "notes", "dataType": "string",
    "validations": [{ "type": "required" }] },
  { "columnName": "customer_ref", "dataType": "string",
    "validations": [{ "type": "optional" }] },
  { "columnName": "region", "dataType": "string", "defaultValue": "UNKNOWN",
"columns": [
Here order_id, amount, and placed_at are required and must carry a non-null value; notes is required (the key must be present) but its value can be null; customer_ref is optional — callers can omit it and it's stored as null; and region is optional too, but is stored as "UNKNOWN" rather than null when omitted, thanks to its defaultValue.
Object-level validations​
A table can also declare object-level validations in an objectValidations array — asynchronous data-quality checks (freshness, missing_data_validation), foreign-key checks (foreign_key, async_foreign_key), and the unique-key toggle, evaluated after rollout on demand rather than inline on each ingest. See Object-level validations for the full reference.
Failures are recorded asynchronously and surface in the Data Quality Dashboard. See Error codes for the object-level failure codes. Set objectValidations at save-schema or Add a custom object, and change them later with Patch a solution's schema.
Example request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema' \
  -d '{
    "appName": "quote-pricing",
    "appVersion": "1.0.0",
    "schemaDefinition": "{ \"tables\": [ { \"name\": \"products\", \"columns\": [ ... ] } ] }",
    "dryRun": false
curl -X POST \
  -d '{
    "dryRun": false
Response (201 Created)​
  "id": "7be5d475-4494-4c73-a012-2c27c6da5f38",
  "schemaSynergyTag": null,
  "createdAt": "2026-04-24T07:23:19.264Z",
  "updatedAt": "2026-04-24T07:23:19.264Z",
  "message": "Standard schema saved successfully"
Status codes​
  • 201 Created — schema saved
  • 200 OK — dryRun: true validation succeeded
  • 400 Bad Request — invalid schemaDefinition
  • 409 Conflict — a schema with this appName + appVersion already exists
  • 500 Internal Server Error — unexpected failure
Roll out a schema to a tenant solution​
Creates the warehouse tables for a tenant solution by referencing a previously saved standard schema. Each table is created alongside its <table_name>_failed_rows companion table — used by asynchronous validation to record failed rows.
POST https://ingestion.peak.ai/api/v2/schema/rollout
Payload​
solutionNameYesTenant-specific solution identifier (e.g., QP_OOTB)
targetSchemaNameYesWarehouse schema where tables will be created (e.g., STAGE)
appNameYesThe standard schema's appName
appVersionYesThe standard schema's appVersion
prefixNoString prepended to every table name during creation
suffixNoString appended to every table name during creation
Example request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/rollout' \
  -d '{
    "solutionName": "QP_OOTB",
    "targetSchemaName": "STAGE",
    "prefix": "QP_",
    "suffix": "_OOTB"
curl -X POST \
  -d '{
    "prefix": "QP_",
    "suffix": "_OOTB"
  "id": "f81c9af3-65ce-4dfe-9cd5-855ebb79e617",
  "schemaVersion": 1,
  "prefix": "QP_",
  "suffix": "_OOTB",
  "createdAt": 1745484199264,
  "message": "Schema rolled out successfully",
  "successfulObjects": {
    "QP_PRODUCT_OOTB": "Created",
    "QP_CUSTOMER_OOTB": "Created"
  "failedObjects": {}
  "schemaVersion": 1,
  "prefix": "QP_",
  "suffix": "_OOTB",
  "failedObjects": {}
Status codes​
  • 201 Created — every table was created
  • 207 Multi-Status — some tables succeeded, some failed; inspect successfulObjects and failedObjects
  • 400 Bad Request — request validation failed (e.g., unknown appName/appVersion)
  • 500 Internal Server Error — every table failed, or unexpected failure
Audit columns added at rollout​
Each table created by a rollout includes a fixed set of audit columns alongside the business columns from your schema. These are populated automatically by the API — you do not send them in your ingest payload, and they will not collide with your own column names.
Data table — every rolled-out table includes these audit columns:
ColumnDescription
PEAKAUDITREQUESTIDIdentifier of the request that ingested the row
PEAKAUDITCREATEDATTimestamp when the row was first inserted
PEAKAUDITUPDATEDATTimestamp when the row was last updated (changes on every UPSERT)
PEAKAUDITREQUESTTIMETimestamp the caller's request was received
PEAKAUDITCREATEDBYPlatform user identifier from the x-auth-platformuserid header
PEAKAUDITERRORSJSON array of the foreign-key violations flagged on the row, each { "errorCode", "errorDetails", "severity", "constraintName", "flaggedAt" }, or NULL when none. See Foreign-key checks.
PEAKAUDITLASTVALIDATIONTIMETimestamp of the run that last flagged the row. Cleared together with PEAKAUDITERRORS when the violation resolves.
SYSPRIMARYKEYSynthetic primary key used internally to deduplicate and join rows
Failed-rows table (<table_name>_failed_rows) — the companion table created next to each data table includes the audit columns above (except PEAKAUDITUPDATEDAT, since failed rows are not updated), plus two extras specific to failure tracking:
ColumnDescription
LOADTYPE"upsert" or "append", derived from the operationType of the request that produced the failed row
ERRORCODESJSON-encoded list of error codes the row failed against (see API Guide — Error codes)
In practice, you don't need to query the failed-rows table directly — the Data Quality Dashboard surfaces the same data with filters and drill-downs. See Data Quality Dashboard.
Note:
Column-name casing differs by warehouse: Snowflake stores them uppercase and unquoted (PEAKAUDITREQUESTID); Redshift stores them quoted and camel-cased ("peakAuditRequestId"). They refer to the same logical column.
Upgrade a rolled-out schema to a new version​
Computes the diff between two standard schema versions and applies only additive changes (new tables, new columns) to your already-rolled-out solution. Any removal — of a table, column, primary key, unique key, or foreign key — is rejected with 400 Bad Request.
POST https://ingestion.peak.ai/api/v2/schema/upgrade
Payload​
solutionNameYesThe tenant solution to upgrade
appNameYesApplication identifier (must match the one used at rollout)
previousAppVersionYesThe version currently rolled out
newAppVersionYesThe version to upgrade to
Example request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/upgrade' \
  -d '{
    "previousAppVersion": "1.0.0",
    "newAppVersion": "1.1.0"
curl -X POST \
  -d '{
Response (200 OK)​
  "newAppVersion": "1.1.0",
  "schemaVersion": 2,
  "message": "Schema upgrade completed successfully",
    "QP_PRODUCT_OOTB": "Added column: discount_pct",
    "QP_STOCK_OOTB": "Created"
  "failedObjects": {},
  "skippedObjects": {
    "QP_CUSTOMER_OOTB": "No changes detected"
  "schemaVersion": 2,
  "skippedObjects": {
Status codes​
  • 200 OK — every applicable change succeeded (or the diff was empty)
  • 207 Multi-Status — some changes succeeded, some failed
  • 400 Bad Request — diff includes a removal; the response's validationErrors[] lists the removals detected
  • 404 Not Found — solutionName, appName, or one of the versions does not exist
  • 500 Internal Server Error — every change failed, or unexpected failure
Add a new column​
Adds a single column to an existing table without going through a full version upgrade. The new column is added with the supplied validations and default value.
POST https://ingestion.peak.ai/api/v2/schema/{objectName}/add-attribute
Path parameters​
  • objectName — The fully qualified warehouse table name as returned by Describe a solution's schema. For a standard rolled-out table that includes any solution prefix/suffix (for example QP_PRODUCT_OOTB); for a custom table it includes the automatic C_ (Snowflake) or c_ (Redshift) table prefix as well (for example C_sales_orders_v1). The lookup is case-insensitive.
Automatic column-name prefix on standard tables​
When you add a column to a table created through a standard schema rollout, the API automatically prefixes the column name in the warehouse — C_ on Snowflake (uppercase), c_ on Redshift (lowercase) — to distinguish post-rollout additions from the original schema columns. The customer sends the raw name in columnName; the prefixed name is what gets created in the warehouse, and what the response returns.
You send columnNameTenant warehouseWarehouse column createdResponse columnName
discount_pctSnowflakeC_discount_pct"C_discount_pct"
discount_pctRedshiftc_discount_pct"c_discount_pct"
Queries against the warehouse table must reference the prefixed name (SELECT C_discount_pct FROM ...).
Exception: columns added to a custom object are not prefixed — they keep the raw name you sent. The intent: the table's own C_/c_ prefix already signals it's a custom table, so individual columns inside don't need an additional marker.
Payload​
solutionNameYesThe tenant solution the table belongs to
columnNameYesRaw column name. The warehouse column is created with a C_/c_ prefix on standard tables (see above); custom-table columns are not prefixed.
dataTypeYesOne of the supported data types — boolean, date, float, integer, json, numeric, string, timestamp.
formatConditionalFormat string for date/timestamp types. Use YYYY-MM-DD for date; YYYY-MM-DD HH:MI:SS or YYYY-MM-DD HH:MI:SS ±hh:mm for timestamp.
precisionConditionalTotal digits (1–38). Required for numeric; rejected for float.
scaleConditionalDecimal digits (0–37). Required for numeric; rejected for float.
defaultValueNoDefault value applied to existing rows after the column is added.
validationsYesNon-empty array of validation rules. Each entry is { "type": "<rule>", ... } (for example {"type": "nonNull"}, {"type": "maxLength", "value": 100}). As with save-schema, must declare exactly one of {"type": "required"} or {"type": "optional"}.
Controlling required-ness and nullability on the new column​
The required/optional marker controls the key, and nonNull controls the value — pick the combination that matches how the column should behave:
Key may be missing; stored as null (or defaultValue) when absentoptionalNo
As at save-schema, a column must declare exactly one of required/optional, and nonNull requires required (a nonNull + optional column is rejected with 400 Bad Request). The doc pages on the per-table guide reflect the marker and nonNull as the Required and Nullable columns of the attributes table.
defaultValue + nonNull are mutually exclusive. If you supply a defaultValue, the API rejects a payload that also lists {"type": "nonNull"} in validations with 400 Bad Request: "Cannot use 'nonNull' validation with defaultValue. defaultValue ensures the field always has a value." — pick one of the two, not both.
Example request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/QP_PRODUCT_OOTB/add-attribute' \
  -d '{
    "columnName": "discount_pct",
    "precision": 5,
    "scale": 2,
    "defaultValue": 0,
    "validations": [
      { "type": "optional" },
      { "type": "range", "min": 0, "max": 100 }
curl -X POST \
  -d '{
    "precision": 5,
    "scale": 2,
    "defaultValue": 0,
    "validations": [
Response (200 OK)​
  "requestId": "7be5d475-4494-4c73-a012-2c27c6da5f38",
  "message": "Column added successfully",
  "columnName": "C_discount_pct",
  "tableName": "QP_PRODUCT_OOTB",
  "schemaVersion": 2
  "schemaVersion": 2
The columnName in the response is the prefixed warehouse column name (C_discount_pct on Snowflake, c_discount_pct on Redshift) — that's the name you'll use when querying the warehouse. For a custom table, this would be the raw name you sent.
Status codes​
  • 200 OK — column added
  • 400 Bad Request — invalid validations, unsupported dataType, or column already exists
Patch a solution's schema​
Amends an existing tenant solution's schema in place. Each call creates a new schema version; the latest version is always the one in effect. Use it to adjust validations and per-table settings after rollout without going through a full schema upgrade.
PATCH https://ingestion.peak.ai/api/v2/schema/solutions
What you can patch:
  • objectValidations — the supplied array fully replaces the table's object-level validations. Send an empty array to clear them; omit the field to leave them unchanged.
  • Custom-column validations — replaces a custom column's validations. The same backward-compatibility rule as save-schema applies: you cannot tighten a constraint such that already-valid data would fail.
  • scheduleConfig — the per-table ingestion cron.
  • description — on custom tables and custom columns.
Validations and descriptions can only be changed on custom columns/tables. Structural changes — adding or removing columns, changing data types, precision/scale, primary keys, or unique keys — are not supported here; use a schema upgrade or add-column instead.
Payload​
solutionNameYesThe tenant solution to patch.
tablesYesNon-empty array of per-table patches.
tables[].objectNameYesThe stored table name (including any C_/c_ custom-table prefix).
tables[].objectValidationsNoFull replacement of the table's object-level validations. An empty array clears them.
tables[].scheduleConfigNoPer-table ingestion cron override.
tables[].descriptionNoTable description (custom tables only).
tables[].columnsNoColumn-level patches — each { "columnName": ..., "validations": [...], "description": ... } (custom columns only).
Example request​
curl -X PATCH \
  'https://ingestion.peak.ai/api/v2/schema/solutions' \
  -d '{
    "tables": [
        "objectName": "C_sales_orders_v1",
        "objectValidations": [
          { "type": "freshness",
            "params": { "column": "placed_at", "threshold": 24, "unit": "hours" },
            "enabled": true, "severity": "error" },
          { "type": "missing_data_validation",
            "params": { "column": "placed_at", "interval": 1, "unit": "days", "minRowCount": 100 },
            "enabled": true, "severity": "warn" },
          { "type": "unique_key", "enabled": false },
          { "type": "foreign_key", "enabled": false }
curl -X PATCH \
  -d '{
    "tables": [
Note:
objectValidations in a PATCH is a full replacement, not a merge. The array you send becomes the table's complete set of object-level validations — any existing entry you leave out is removed. To change a single rule, send the full set you want the table to end up with. An empty array clears them all; omitting the field entirely leaves them unchanged. (Custom-column validations patch the same way.)
Response (200 OK)​
  "schemaVersion": 4,
  "message": "Schema patched successfully",
  "updatedTables": ["C_sales_orders_v1"]
  "schemaVersion": 4,
Status codes​
  • 200 OK — schema patched; the response carries the new schemaVersion
  • 400 Bad Request — a non-backward-compatible validation change, an invalid rule or cron expression, or a non-custom column/table was targeted
  • 401 Unauthorized
  • 404 Not Found — the solution, table, or column does not exist
  • 409 Conflict — the schema is being modified concurrently; retry
Add a custom object​
Adds a custom object (table) to an existing tenant solution. Use this when a tenant needs a table beyond what the application's standard schema provides — for example, a tenant-specific staging table or a derived table that isn't part of the canonical schema. The columns are defined inline in the request payload.
The solution must already exist — create it first via Roll out a schema to a tenant solution. The new table inherits the solution's existing targetSchemaName automatically; you do not specify it on the request. Calling this endpoint with a solutionName that does not exist returns 404 Not Found.
POST https://ingestion.peak.ai/api/v2/schema/add-object
Note:
The older path POST /api/v2/schema/custom-table still works but is deprecated. Switching to add-object is recommended; it pairs with Add a new column (add-attribute).
Automatic name prefixing: the created warehouse table name is prefixed to distinguish it from standard-rollout tables — C_ on Snowflake (uppercase), c_ on Redshift (lowercase). The prefix is added to the front of the final table name, including any partner-supplied prefix/suffix. So tableName: "orders" with prefix: "sales_" and suffix: "_v1" becomes C_sales_orders_v1 on Snowflake. Column names are not prefixed.
Payload:
solutionNameYesThe existing tenant solution to attach the new table to (e.g., QP_OOTB). Must already be rolled out.
tableNameYesBase name for the new table. See the prefixing note above for how the final warehouse name is composed.
columnsYesNon-empty list of column definitions. Each entry follows the same shape used in the standard schema (columnName, dataType, optional format, precision, scale, defaultValue, and a validations array). As at save-schema, every column's validations must declare exactly one of { "type": "required" } or { "type": "optional" }, and primary-key columns must be required.
primaryKeysYesNon-empty array of column names that form the primary key. Every name must match a column declared in columns (case-insensitive).
uniqueKeysNoArray of arrays — each inner array is a set of column names that must be unique together
prefixNoAdditional string prepended to the table name (inside the automatic C_/c_ prefix)
suffixNoString appended to the table name
objectValidationsNoObject-level validation rules to attach at creation. Same shape as Object-level validations.
Example request:
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/add-object' \
  -d '{
    "tableName": "orders",
    "prefix": "sales_",
    "suffix": "_v1",
    "columns": [
      { "columnName": "ORDER_ID", "dataType": "string", "validations": [{ "type": "required" }] },
      { "columnName": "AMOUNT", "dataType": "numeric", "precision": 10, "scale": 2, "validations": [{ "type": "required" }] },
      { "columnName": "PLACED_AT", "dataType": "timestamp", "validations": [{ "type": "required" }, { "type": "timestampFormat", "format": "YYYY-MM-DD HH:MI:SS" }] },
      { "columnName": "NOTES", "dataType": "string", "validations": [{ "type": "optional" }] }
    "primaryKeys": ["ORDER_ID"],
        "params": { "column": "PLACED_AT", "threshold": 24, "unit": "hours" },
curl -X POST \
  -d '{
    "prefix": "sales_",
    "suffix": "_v1",
    "columns": [
ORDER_ID, AMOUNT, and PLACED_AT are required; NOTES is optional, so callers can omit it.
Response (201 Created):
  "message": "Custom table created successfully",
  "tableName": "C_sales_orders_v1",
  "schemaVersion": 3,
  "columnCount": 4
  "schemaVersion": 3,
  "columnCount": 4
The warehouse table name returned in the response includes the automatic C_/c_ prefix. Ingest into the custom table by sending requests to POST /api/v2/objects/<returned-tableName> — the same endpoint as any other table.
Status codes:
  • 201 Created — custom table created
  • 400 Bad Request — validation failure (missing required fields, invalid column definitions, schema-name issues)
  • 401 Unauthorized
  • 404 Not Found — referenced solution or schema does not exist
  • 409 Conflict — a table with this name already exists in the solution
List solutions for the tenant​
Returns every solution that has been rolled out for the calling tenant, with the latest version's metadata. Useful for populating dropdowns and checking what's available.
GET https://ingestion.peak.ai/api/v2/schema/solutions
Response (200 OK)​
  "solutions": [
      "prefix": "QP_",
      "suffix": "_OOTB",
      "schemaVersion": 2,
      "tableCount": 5,
      "solutionName": "atest_automation_5",
      "targetSchemaName": "stage",
      "prefix": null,
      "suffix": null,
      "schemaVersion": 1,
      "tableCount": 3,
      "createdAt": "2026-01-20T09:06:15.891Z"
  "solutions": [
      "prefix": "QP_",
      "suffix": "_OOTB",
      "schemaVersion": 2,
      "tableCount": 5,
      "prefix": null,
      "suffix": null,
      "schemaVersion": 1,
      "tableCount": 3,
The solutions array is empty if no rollouts have happened yet for the tenant.
Describe a solution's schema​
Returns the latest version's full schema for a given solution, including every table and its columns.
GET https://ingestion.peak.ai/api/v2/schema?solutionName={solutionName}
Query parameters​
  • solutionName (required) — the solution to describe
Response (200 OK)​
Each table in the schema array is keyed by objectName — the full warehouse table name as it exists in your warehouse, including any solution-level prefix/suffix from rollout. Tables created through Add a custom object appear here with their automatic C_ (Snowflake) or c_ (Redshift) prefix as well.
  "appVersion": "1.1.0",
  "prefix": "QP_",
  "suffix": "_OOTB",
  "schema": [
      "objectName": "QP_PRODUCT_OOTB",
      "primaryKeys": ["product_id"],
      "uniqueKeys": [],
      "foreignKeys": [],
      "columns": [
        { "columnName": "product_id",    "dataType": "string",  "validations": [{ "type": "required" }, { "type": "nonNull" }] },
        { "columnName": "product_name",  "dataType": "string",  "validations": [{ "type": "required" }, { "type": "maxLength", "value": 255 }] },
        { "columnName": "discount_pct",  "dataType": "numeric", "precision": 5, "scale": 2, "validations": [{ "type": "required" }, { "type": "range", "min": 0, "max": 100 }] }
      "isRolledOut": true,
      "rolloutState": "SUCCESS",
      "primaryKeys": ["order_id"],
      "uniqueKeys": [],
      "foreignKeys": [],
      "columns": [
        { "columnName": "order_id",  "dataType": "string",  "validations": [{ "type": "required" }, { "type": "nonNull" }] },
        { "columnName": "amount",    "dataType": "numeric", "precision": 10, "scale": 2, "validations": [{ "type": "required" }, { "type": "nonNull" }] },
        { "columnName": "placed_at", "dataType": "timestamp", "validations": [{ "type": "required" }, { "type": "nonNull" }, { "type": "timestampFormat", "format": "YYYY-MM-DD HH:MI:SS" }] }
  "prefix": "QP_",
  "suffix": "_OOTB",
  "schema": [
      "uniqueKeys": [],
      "foreignKeys": [],
      "columns": [
      "uniqueKeys": [],
      "foreignKeys": [],
      "columns": [
The objectName value is what you use as the URL path on POST /api/v2/objects/{objectName} when ingesting into the table — including the C_/c_ prefix for custom tables.
Status codes​
  • 200 OK — schema returned
  • 404 Not Found — no solution with that name has been rolled out for the calling tenant
Verbinden
Benötigen Sie Hilfe? Support
