industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Transfers
Transfers API resource representing inter-location stock movements, such as shipments between distribution centres, stores, and warehouses.
Overview​
The Transfers resource represents inter-location stock movements, such as goods shipped from a distribution centre to a store or between warehouses. Each record tracks the movement of a specific product along with planned and actual departure details, delivery quantities, and the current transfer status.
Resource Endpoint​
/api/v2/ingest/object/{prefix}TRANSFERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Transfers records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product being transferred. Part of the composite primary key.
  • location_id (string) - Unique identifier for the destination location. Part of the composite primary key.
  • order_number (string) - Unique identifier for the transfer order. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product being transferred
location_idstringYesUnique identifier for the destination location receiving the stock
order_numberstringYesUnique identifier for this transfer order
source_idstringYesIdentifier of the origin location or supplier dispatching the stock
ordered_attimestampYesDatetime when the transfer was initiated
ordered_unitsintegerYesNumber of units requested in the transfer
expected_departure_datetimestampYesPlanned datetime for the stock to depart the origin location
actual_departure_datetimestampNoActual datetime the stock departed the origin location
expected_delivery_datetimestampYesPlanned datetime for the stock to arrive at the destination location
actual_delivery_datetimestampNoActual datetime the stock arrived at the destination location
delivered_unitsintegerNoNumber of units actually delivered to the destination location
statusstringNoCurrent status of the transfer (for example, "pending", "in_transit", "delivered")
Relationships​
Outbound References​
The transfers resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by transfers:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "order_number": "TR-2025-001",
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "source_id": "LOC-002",
      "ordered_at": "2025-01-10 09:00:00",
      "ordered_units": 100,
      "expected_departure_date": "2025-01-14 06:00:00",
      "actual_departure_date": "2025-01-14 07:15:00",
      "expected_delivery_date": "2025-01-16 06:00:00",
      "actual_delivery_date": "2025-01-16 08:30:00",
      "delivered_units": 100,
      "status": "delivered"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_TRANSFERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id, location_id, and order_number together form the composite primary key. All three fields must be provided on every record.
  • location_id represents the destination location; the origin is captured in source_id, which may reference either a location or a supplier identifier.
  • expected_departure_date and expected_delivery_date capture the planned dispatch and arrival datetimes; populate actual_departure_date, actual_delivery_date, and delivered_units once the transfer has been dispatched or completed.
  • All timestamps must be provided in YYYY-MM-DD HH:MM:SS format.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
Verbinden
Benötigen Sie Hilfe? Support
