industry-department-solutions
- Overview
- API Resources
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Products Parent Child Mapping
Products Parent Child Mapping API resource defining parent-child relationships between products for substitution and hierarchy modelling in the Rebuy & Replenishment model.
The Products Parent Child Mapping resource defines parent-child relationships between products. Each record links a child product to its parent, along with a label and rank that describe the child's role within the hierarchy. This mapping supports substitution and product hierarchy modelling in the Rebuy & Replenishment model.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCTS_PARENT_CHILD_MAPPING{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) Products Parent Child Mapping records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- child_id (string) - Unique identifier for the child product. Used as the primary key for deduplication and UPSERT operations.
Attributes
| Attribute | Data Type | Required | Description |
parent_id | string | Yes | Unique identifier of the parent product in the hierarchy |
child_id | string | Yes | Unique identifier of the child product mapped to the parent |
child_label | string | Yes | Human-readable label describing the child product's role or variant |
child_rank | integer | Yes | Ordering rank of the child within the parent's hierarchy |
Relationships
Outbound References
The products_parent_child_mapping resource does not reference any downstream resources as foreign keys.
Inbound References
The following resources are referenced by products_parent_child_mapping:
- products —
parent_id→products.product_id - products —
child_id→products.product_id
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"parent_id": "PROD-001",
"child_id": "PROD-002",
"child_label": "Small",
"child_rank": 1
"operationType": "UPSERT"
"data": [
"child_rank": 1
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCTS_PARENT_CHILD_MAPPING_OOTB' \
-d '{
"data": [
"child_rank": 1
curl -X POST \
-d '{
"data": [
"child_rank": 1
Important Notes
child_idis the primary key, used for deduplication and UPSERT operations. Each child product maps to exactly one parent.parent_idandchild_idmust both correspond to existing records in the Products resource.child_rankorders sibling children under the same parent; lower ranks are typically presented first.- Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
