industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Order Parameters
Order Parameters API resource defining replenishment configuration per product-location-source combination, including planning parameters used by the inventory optimization engine.
Overview​
The Order Parameters resource represents the replenishment configuration for a product-location-source combination. Each record defines the planning parameters used by the inventory optimisation engine to calculate recommended order quantities, including review cycles, service level targets, lead times, and minimum stock guardrails.
Resource Endpoint​
/api/v2/ingest/object/{prefix}ORDER_PARAMETERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Order Parameters records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Part of the composite primary key.
  • location_id (string) - Unique identifier for the location these parameters apply to. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product
location_idstringYesUnique identifier for the location these parameters apply to
source_idstringYesIdentifier of the supplier or source from which replenishment is made
review_period_daysintegerYesNumber of days between inventory review cycles
service_levelfloatYesTarget service level as a decimal (for example, 0.95 for 95%)
lead_time_daysintegerYesNumber of days from order placement to expected receipt
minimum_guardrailintegerNoMinimum stock quantity to maintain as a safety buffer
Relationships​
Outbound References​
The order_parameters resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by order_parameters:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "source_id": "SUP-001",
      "review_period_days": 7,
      "service_level": 0.95,
      "lead_time_days": 14,
      "minimum_guardrail": 50
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_ORDER_PARAMETERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id and location_id together form the composite primary key. Both fields must be provided on every record.
  • service_level should be expressed as a decimal between 0 and 1 (for example, 0.95 for a 95% target fill rate).
  • source_id should correspond to a valid supplier_id in the Suppliers resource.
  • location_id should correspond to a valid record in the Locations resource.
  • minimum_guardrail is optional; when omitted, the system will not enforce a minimum stock floor for this product-location.
Verbinden
Benötigen Sie Hilfe? Support
