industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Locations
Locations API resource representing physical and logical nodes in the supply chain network, including distribution centres, retail stores, and factories.
Overview​
The Locations resource represents physical or logical nodes in the supply chain network, such as distribution centres, retail stores, and factories. Each location record captures the site's identity, geographic context, and its functional role within the inventory management system.
Resource Endpoint​
/api/v2/ingest/object/{prefix}LOCATIONS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Locations records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • location_id (string) - Unique identifier for the location. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
location_idstringYesUnique identifier for the location
location_namestringNoHuman-readable name of the location (for example, "Central Warehouse")
countrystringNoCountry in which the location resides
is_storebooleanYesIndicates whether the location is a retail store
is_dcbooleanYesIndicates whether the location is a distribution centre
is_factorybooleanYesIndicates whether the location is a manufacturing facility
Relationships​
Outbound References​
The locations resource does not reference any other resource as a foreign key.
Inbound References​
The following resources reference locations via location_id:
  • stock_daily — location_id → locations.location_id
  • pricing — location_id → locations.location_id
  • order_parameters — location_id → locations.location_id
  • purchase_orders — location_id → locations.location_id
  • transfers — location_id → locations.location_id
  • sku_calendar — location_id → locations.location_id
  • sales_daily — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "location_id": "LOC-001",
      "location_name": "Central Warehouse",
      "country": "United Kingdom",
      "is_store": false,
      "is_dc": true,
      "is_factory": false
  "operationType": "UPSERT"
  "data": [
      "is_store": false,
      "is_dc": true,
      "is_factory": false
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_LOCATIONS_OOTB' \
  -d '{
    "data": [
        "is_store": false,
        "is_dc": true,
        "is_factory": false
curl -X POST \
  -d '{
    "data": [
        "is_store": false,
        "is_dc": true,
        "is_factory": false
Important Notes​
  • location_id is the primary key, used for deduplication and UPSERT operations.
  • The boolean flags is_store, is_dc, and is_factory are all required. A location may have more than one flag set to true if it serves multiple roles.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
Verbinden
Benötigen Sie Hilfe? Support
