industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Stock
stock API resource for the Merchandising solution representing inventory levels per product-location combination on a daily basis.
Overview​
The stock resource represents inventory levels for products at specific locations on specific dates. This resource tracks stock quantities over time for inventory management.
Resource Endpoint​
/api/v2/ingest/object/{prefix}STOCK{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) stock records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • location_id (string) - Foreign key reference to locations
  • product_id (string) - Foreign key reference to products
  • stock_date_at (date) - Date for the stock snapshot
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
location_idstringYesNoLocation identifier (Primary Key, Foreign Key)
product_idstringYesNoProduct identifier (Primary Key, Foreign Key)
stock_date_atdateYesNoStock snapshot date (Primary Key)
stock_unitsintegerYesNoNumber of units in stock
stock_idstringYesYesAlternative stock record identifier
created_attimestampYesYesTimestamp when the record was created
updated_attimestampYesYesTimestamp when the record was last updated
Relationships​
Outbound References​
None
Inbound References​
  • location - Foreign key location_id references location
  • product - Foreign key product_id references product
JSON Representation​
  "solutionName": "MP_OOTB",
  "data": [
      "location_id": "LOC-UK-001",
      "product_id": "PROD-001",
      "stock_date_at": "2025-01-28",
      "stock_units": 450,
      "stock_id": "STK-2025-001",
      "created_at": "2025-01-28T00:00:00Z",
      "updated_at": "2025-01-28T10:00:00Z"
  "operationType": "UPSERT"
  "data": [
      "stock_units": 450,
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/MP_STOCK_OOTB' \
  -d '{
    "data": [
        "stock_units": 450,
curl -X POST \
  -d '{
    "data": [
        "stock_units": 450,
Important Notes​
  • Foreign Key Dependencies: Requires valid product_id and location_id to exist in their respective tables
  • Daily Snapshots: Captures stock levels at specific dates for historical tracking
  • Location-Specific: Stock is tracked separately for each location
  • Inventory Management: Essential for stock level monitoring and replenishment planning
  • Custom Attributes: Additional custom attributes can be added using the /STOCK/add-attribute endpoint
  • Data Validation: All attributes are validated according to their defined data types
Verbinden
Benötigen Sie Hilfe? Support
