industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Manufacturing Orders
Manufacturing Orders API resource representing production work orders governing internal manufacture of products at factory locations.
Overview​
The Manufacturing Orders resource represents production work orders that govern the internal manufacture of products at factory locations. Each record tracks a single manufacturing order through its full lifecycle, from the initial planned quantities and scheduled dates through to actual production start and end times, units produced, and current status.
Resource Endpoint​
/api/v2/ingest/object/{prefix}MANUFACTURING_ORDERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Manufacturing Orders records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product being manufactured. Part of the composite primary key.
  • location_id (string) - Unique identifier for the factory location. Part of the composite primary key.
  • order_number (string) - Unique identifier for the manufacturing order. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product being manufactured
location_idstringYesUnique identifier for the factory or production site
order_numberstringYesUnique identifier for this manufacturing order
source_idstringYesIdentifier of the production line or internal source initiating the order
ordered_attimestampYesDatetime when the manufacturing order was created
ordered_unitsintegerYesNumber of units planned for production
expected_start_datetimestampYesPlanned datetime for production to begin
actual_start_datetimestampNoActual datetime production commenced
expected_end_datetimestampYesPlanned datetime for production to be completed
actual_end_datetimestampNoActual datetime production was completed
produced_unitsintegerNoNumber of units actually produced
statusstringNoCurrent status of the manufacturing order (for example, "scheduled", "in_progress", "completed")
Relationships​
Outbound References​
The manufacturing_orders resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by manufacturing_orders:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "order_number": "MO-2025-001",
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "source_id": "LINE-001",
      "ordered_at": "2025-01-05 08:00:00",
      "ordered_units": 500,
      "expected_start_date": "2025-01-10 06:00:00",
      "actual_start_date": "2025-01-10 06:30:00",
      "expected_end_date": "2025-01-12 18:00:00",
      "actual_end_date": "2025-01-12 17:45:00",
      "produced_units": 498,
      "status": "completed"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_MANUFACTURING_ORDERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id, location_id, and order_number together form the composite primary key. All three fields must be provided on every record.
  • expected_start_date and expected_end_date are required planned dates; their actual_ counterparts are optional and should be populated as production progresses.
  • produced_units and actual_start_date/actual_end_date should be updated incrementally as the order progresses.
  • The location_id for a manufacturing order should reference a location where is_factory is set to true.
  • All timestamps must be provided in YYYY-MM-DD HH:MM:SS format.
Verbinden
Benötigen Sie Hilfe? Support
