industry-department-solutions
Dieser Inhalt ist in der ausgewählten Sprache nicht verfügbar. Stattdessen wird der Inhalt in englischer Sprache angezeigt.
Data Onboarding Checklist
Checklist for tracking progress through data preparation and submission stages when onboarding to the Supply Chain & Retail Solutions Data Ingestion API.
Use this checklist to track your progress as you prepare and submit data to the Supply Chain & Retail Solutions ingestion API. Complete each item before moving on to the next stage.
Before you begin​
  • Read the Getting Started guide
  • Confirm you have access to platform.peak.ai
  • Generate a Personal Access Token (PAT) from the Access Tokens page in the platform
Gather your solution details​
Submit a support ticket if you do not have these details already.
  • Obtain your solution name (e.g., QP_OOTB)
  • Obtain your prefix (e.g., QP_)
  • Obtain your suffix (e.g., _OOTB)
  • Identify the target schema name (e.g., STAGE)
  • Identify the app name and app version of the standard schema you will roll out
  • Confirm your API base URL (if your tenant is in the Ireland region, use the default base URL https://ingestion.peak.ai; if your tenant is in any other region, use your region-specific base URL — for example, https://ingestion.peaksydney.peak.ai for Sydney — and raise a support ticket if you have not been given one. See API host and reference for details.)
Roll out the solution tables​
This step creates the warehouse tables (and matching <table_name>_failed_rows tables) you will ingest into. See Schema lifecycle for the full reference.
  • Confirm a standard schema has been saved for your appName + appVersion
  • Send a POST /api/v2/schema/rollout request for your solutionName — see the linked reference for the full payload, example request, and response
  • Verify the response lists every expected table under successfulObjects and that failedObjects is empty
  • (Optional) Use GET /api/v2/schema/solutions to confirm the rollout is registered for your tenant
Prepare your data​
Submit your data​
  • Choose your operation type: UPSERT (insert or update) or APPEND (insert only)
  • Construct your API request using the ingestion URL pattern: POST {base-URL}/api/v2/objects/{prefix}{OBJECT_NAME}{suffix} — use your tenant's base URL (see API host and reference)
  • Stay within the ingestion limits: up to 2000 rows per request and 50 requests per second per tenant
  • Send a test request with a small data sample (consider dryRun: true for a no-write smoke test) and verify a successful response
  • Review the API Guide for error codes if any validation errors are returned. A 207 Multi-Status response means part of the batch was accepted and part rejected.
  • Ingest your full dataset
A 200 response confirms your rows were accepted; they are typically queryable within seconds.
Monitor your ingestion​
  • Confirm aggregate outcomes (records ingested, pass rate, top error codes) in the Data Quality Dashboard in your Peak tenant
  • Review any failed rows in the dashboard's failed-rows detail page
  • To investigate a specific batch, note the requestId from each ingestion response and use it to filter the Data Quality Dashboard
Deploy the application​
  • Confirm the selected application and version are deployed to the Library in your Peak tenant, making it available for use
Optional​
  • Add custom attributes to extend the schema for your business needs
  • Review the default scheduled ingestion schedule (every 30 minutes) and request a custom cron for any tables that need a different one
  • When your application moves to a new version, upgrade your rolled-out schema (additive changes only — new tables and columns). See Schema lifecycle
Verbinden
Benötigen Sie Hilfe? Support
