uipathctl-Referenzhandbuch
uipathctl rke2 Prereq
Beschreibung
Befehle zur Voraussetzungsprüfung.
uipathctl rke2 prereq [flags]
Optionen
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text] (default text)
      --upgrade            include upgrade-related checks
  • Beschreibung
  • Optionen
  • Von übergeordneten Befehlen geerbte Optionen
Verbinden
Benötigen Sie Hilfe? Support
