Ausgabebeispiel: Überprüfung der Voraussetzungen
Das folgende Beispiel zeigt die Ausgabe, die Sie nach der Überprüfung der Infrastrukturvoraussetzungen im Rahmen der Automation Suite-Installation erhalten können. Weitere Informationen finden Sie unter Überprüfen der Infrastrukturvoraussetzungen.
 ℹ️  [empty-app] Creating Argo CD application for component empty-app...
 ℹ️  [empty-app] Waiting for Argo CD application for component empty-app to synchronize...
Ran cluster/ checks...
    Ran ORCHESTRATOR(CLASSIC_FOLDERS) checks...
        ✔ successful
Ran local/ checks...
    Ran ARGO checks...
        ✔ successful
    Ran CONNECTIVITY checks...
        ✔ successful
    Ran DEPLOYMENT_PROFILE checks...
        ✔ successful
    Ran DNS(FQDN=APPS.<FQDN>) checks...
        ✔ successful
    Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...
        ✔ successful
    Ran INGRESS checks...[INGRESS][UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
    Ran NAMESPACE checks...
        ✔ successful
    Ran NETWORK-POLICIES checks...
        ✔ successful
    Ran NODE(CPU >= 8, RAM >= 16G) checks...[NODE(CPU >= 8, RAM >= 16G)][LIST_NODES] Listed 4 nodes
        ✔ [AT_LEAST_ONE_NODE] At least one node found
        ✔ [CPU_USAGE] Node os7140768-7db2g-master-0 has 37.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-master-0 has 46.35% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-master-0 has 0.00% of pods in use. Number of pods: 0.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 12.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 13.64% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 6.25% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 8.30% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 18.75% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 11.11% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 0.80% of pods in use. Number of pods: 2.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ⚠  [AS_ROBOTS_NODE_EXISTS] No dedicated node found
    Ran OSS(COMPONENT=CERT-MANAGER) checks...
        ✔ successful
    Ran OSS(COMPONENT=GATEKEEPER) checks...
        ✔ successful
    Ran OSS(COMPONENT=ISTIO) checks...
        ✔ successful
    Ran PERMISSION checks...
        ✔ successful
    Ran PRIORITYCLASS checks...
        ✔ successful
    Ran REGISTRY_PULL checks...
        ✔ successful
    Ran RESOURCE checks...
        ✔ successful
    Ran SECRETS checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS) checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA) checks...
        ✔ successful
Ran nodes/ checks...
Ran CONTROLPLANECONNECTIVITY checks...4/4 nodes successful
Ran DNS(FQDN=APPS.<FQDN>) checks...4/4 nodes successful
Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=BA) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=DATASERVICE) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=ORCHESTRATOR) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=PLATFORM) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=TESTMANAGER) checks...4/4 nodes successful
Ran REDIS(PORT=6380) checks...4/4 nodes successful
Ran SQL(PRODUCT=ASROBOTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONHUB, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONOPS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=BA, TYPE=ODBC) checks...4/4 nodes successful
Ran SQL(PRODUCT=DATASERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=INSIGHTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=NOTIFICATIONSERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=PLATFORM, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=TESTMANAGER, TYPE=ADO) checks...4/4 nodes successful
Checks complete!
        ✔ successful
    Ran ARGO checks...
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
     ⚠  [INGRESS]
        ⚠  [UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
        ✔ successful
        ✔ successful
     ⚠  [NODE(CPU >= 8, RAM >= 16G)]
        ✔ [LIST_NODES] Listed 4 nodes
        ✔ [CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
 ✔ 4/4 nodes successful
Checks complete!
Verbinden
Benötigen Sie Hilfe? Support
