- Überblick
- Vor der Installation
- Clusterverwaltung
- Sichern und Wiederherstellen
- uipathctl-Snapshot
- uipathctl-Snapshot-Sicherung
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Zertifikatverwaltung
- Aktualisierung
- Authentication
- Überwachung und Warnungen
- Fehlersuche und ‑behebung
Kein Support
uipathctl-Referenzhandbuch
Gibt den Zustand einer Komponente aus.
uipathctl health [flags]uipathctl health [flags]--excluded strings components to be excluded from execution, defaults to none
-h, --help help for health
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)--excluded strings components to be excluded from execution, defaults to none
-o, --output output output format. one of [json,yaml,text,junit] (default text)--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
