Letzte Aktualisierung 16. Jan. 2026
Deaktivieren von TX-Prüfsummen-Offloading
Checksum offloading on a network card may cause issues in some setups, including on VMware instances and in Cilium.
If you encounter such issues, you must disable the TX checksum offloading by running the following commands:
  • Für Servermaschinen:
    cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service
    [Unit]
    Description=Disable TX Checksum Offload
    Before=rke2-server.service
    Wants=network-online.target
    After=network-online.target
    [Service]
    Type=oneshot
    ExecStart=/bin/bash -c "ethtool -K $(awk '$2 == 00000000 { print $1; exit }' /proc/net/route) tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true"
    RemainAfterExit=true
    [Install]
    WantedBy=multi-user.target
    EOF
    sudo systemctl enable disable-checksumcat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service
    [Unit]
    [Service]
    Type=oneshot
    [Install]
    EOF
    [Unit]
    [Service]
    Type=oneshot
    [Install]
    EOF
    [Unit]
    [Service]
    Type=oneshot
    [Install]
    EOF
Hilfe erhalten
UiPath Community-Forum
Vertrauen und Sicherheit
© 2005–2026 UiPath. Alle Rechte vorbehalten
