# Get current certificate
> Retrieve the primary and secondary SAML certificate pair for an Automation Suite organization using the Identity API, including required scope and response schema.
Get the certificate pair for the organization.
## API endpoint
`GET https://{yourDomain}/{organizationName}/identity_/api/SamlCertificate/{partitionGlobalId}/certificates`
## Scopes
Requires the following scope: `PM.AuthSetting`.
## Request headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described in [Authentication methods](https://docs.uipath.com/automation-suite/automation-suite/2.2510/api-guide/authentication-methods#authentication-methods).
## Request body
The request body contains only the organization ID, as `partitionGlobalId`.
## Responses
### 200 Success
The certificate pair was successfully retrieved.
  "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "primaryCertificateId": 0,
  "primaryCertificate": "string",
  "primaryCertificateThumbprint": "string",
  "secondaryCertificateId": 0,
  "secondaryCertificate": "string",
  "secondaryCertificateThumbprint": "string"
