# Component Statuses
> <table>
<colgroup>
<col/>
<col/>
<col/>
</colgroup>
<thead>
<tr>
<th>
Status
</th>
<th>
Component Visible for
</th>
<th>
</th>
</tr>
</thead>
<tbody>
<tr>
<td headers="d54350e29">
<p>Draft</p>
</td>
<td headers="d54350e34">
<p>Author</p>
</td>
<td headers="d54350e39">
<ul>
<li>The author uploaded a component but does not submit it.</li>
<li>The curator rejected the component in the curation flow with - needs update reason.</li>
<li>The author submitted the component but then withdrawn it.</li>
</ul>
</td>
</tr>
<tr>
<p>Submitted</p>
</td>
<p>Author</p>
<p>Component Curators</p>
</td>
<p>The author has uploaded a component and submit it. The component remains in this state until the curation process is initiated.</p>
</td>
</tr>
<tr>
<p>In Review</p>
</td>
<p>Author</p>
<p>Assigned Component Curator</p>
</td>
<p>The curator has picked-up the component from the Manage Components list and started curating it.</p>
</td>
</tr>
<tr>
<p>Published</p>
</td>
<p>All Users</p>
</td>
<p>The curator finishes the curation process and decides to publish the component.</p>
</td>
</tr>
<tr>
<p>Rejected Permanently</p>
</td>
<p>Author</p>
</td>
<p>The curator finishes the curation process and decides to permanently reject the component.</p>
</td>
</tr>
<tr>
<p>Rejected Needs Update</p>
</td>
<p>Author</p>
</td>
<ul>
<li>The curator finishes the curation process and decides to send the component back to the author with recommendation for updates.</li>
<li>The status is similar to the draft one, only that this one is used to warn the author that they need to update the component
                                 before submitting the component again.
                              </li>
</ul>
</td>
</tr>
<tr>
<p>Archived</p>
</td>
<p>Author</p>
<p>Users who have downloaded the component</p>
</td>
<p>The author decides to archive the component from My Components - uploads.</p>
</td>
</tr>
</tbody>
</table>
<colgroup>
<col/>
<col/>
<col/>
</colgroup>
Status
Draft
Author
Submitted
Author
Component Curators
In Review
Author
Published
All Users
Author
Component Curators
Author
Component Curators
Archived
Author
