# Submitting a CoE-driven Idea
> Authorized users like Subject Matter Experts, Process Owners, RPA Business Analysts, Process Consultants who know the process in detail, can bypass the Idea Approver's approval flow by sharing a CoE-driven idea. Check out the [Idea Review Phases](automation-idea-review-phases.md) for more information.
Below you can find a graphic display of the CoE-driven idea flow:
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-CoE%20driven.jpg-0e217bcf.webp)
## How to submit a CoE-driven Idea
To start the process click the **Submit idea** button available on the top, right-hand side of the page.
![Submit new](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-649504-59f4d0d3.webp)
On the selection screen, choose **Idea** to proceed with submitting an automation opportunity.
As per your current permissions, you are now asked to select a **Business Area** for your automation. From the dropdown list, choose one that applies. Continue with a Category, Sub-Category, if the case. Based on the selection and according to your permissions, the system loads the list with available idea flows (e.g. Employee-driven idea, **CoE-driven idea**, Citizen Developer automation, Change request, Agentic AI idea) that can be selected in **Idea type**.
:::important
Make sure you have the needed permissions in order to use this feature, as noted in the [CoE-driven Idea](submit-an-idea.md) section.
