# Generating Your API Token
> API token generation for Automation Hub, directing users to the reference page for step-by-step token creation instructions.
To find out how to generate your API token, check the [Generate your Token from Automation Hub](https://docs.uipath.com/automation-hub/reference-generate-your-token-from-automation-hub) page.
