# Component Statuses
> Component statuses in Automation Hub on Automation Suite, describing the states a component passes through during its lifecycle in the platform.
<colgroup>
  <col/>
  <col/>
  <col/>
 </colgroup>
     Status
     Component Visible for
     Draft
     Author
         The author uploaded a component but does not submit it.
         The curator rejected the component in the curation flow with - needs update reason.
         The author submitted the component but then withdrawn it.
     Submitted
     Author  Component Curators
     The author has uploaded a component and submit it. The component remains in this state until the curation process is initiated.
     In Review
     Author  Assigned Component Curator
     The curator has picked-up the component from the Manage Components list and started curating it.
     Published
     All Users
     The curator finishes the curation process and decides to publish the component.
     Rejected Permanently
     The curator finishes the curation process and decides to permanently reject the component.
     Rejected Needs Update
         The curator finishes the curation process and decides to send the component back to the author with recommendation for updates.
         The status is similar to the draft one, only that this one is used to warn the author that they need to update the component before submitting the component again.
     Archived
     Author  Users who have downloaded the component
     The author decides to archive the component from My Components - uploads.
