# Submitting a business process
> Submit a business process to the Automation Hub process repository using a workflow configured for business process submissions.
Submit a business process to add it to the process repository in Automation Hub.
## Prerequisites
* You have the **Authorized User** role or higher.
* At least one workflow in your tenant is configured as a business process workflow by your administrator.
1. Select **Submit new** in the Automation Hub header.
2. On the selection screen, select **Business process**.
   ![Business process selection screen in Automation Hub showing category and workflow options](https://dev-assets.cms.uipath.com/assets/images/automation-hub/automation-hub-business-process-649444-6359ab0c-32ea41b5.webp)
3. Select the business area and category that apply to your business process.
4. Select the workflow you want to use. If only one worklow is available for the selected category, it is pre-selected.
5. Select **Next**.
6. Complete the fields on the assessment page.
   :::note
   The **Sub-process** field is the last question in the **Process details** section of the Overview assessment. Use it to select one or more existing processes that should become sub-processes of the process you are submitting. This field is optional — leave it blank to submit a top-level process with no sub-processes.
7. Select **Link to Studio Web**.
8. Review the linked solution access settings.
   :::note
   Once you link a process in the repository to a solution, by default all users in that group will have read-only access to that solution. If you want to restrict access, you can choose one of the groups in the **User group** drop-down list.
9. Select the Studio Web solution to which you want to link your business process.
10. Select **Submit**.
## Results
The business process is added to the process repository and is visible to all users. You can find your submission under **My Submissions - Processes**.
:::note
The **Cost Benefit Analysis** page is not available for **Business Process** entries. The KPIs and cost metrics in that page are designed for RPA-focused automation scenarios and are not applicable to business process documentation.
