You can enable and disable products in Automation Suite at any point post-installation.
To do that, you must access and update the cluster_config.json
file stored in the /opt/UiPathAutomationSuite
folder, and rerun the service installer step.
Note:
You need to perform these steps only from server nodes.
Step 1: Changing the product selection in the configuration file
- Navigate to the
folder and editcluster_config.json
cd /opt/UiPathAutomationSuite
nano cluster_config.json #optionally use any favourite editor of your choice.
- In the services list, set the
enable
flags totrue
orfalse
for the specific services you want to enable or disable. See the following examples for individual products.
Note:
You can manage Action Center and Apps simply by updating the
enable
flag. Other products might require an additional step to configure the installation. See the following instructions for details.
Enabling or disabling Orchestrator
To enable Orchestrator, set the orchestrator
flag to true
in the cluster_config.json
file.
"orchestrator": {
"enabled": "true" //Set to "false" to disable Orchestrator
"sql_connection_str": "" //Optional and only require to override the default database name
To disable Orchestrator, set the orchestrator
flag to false
file.
Enabling or disabling Action Center
See the following configuration details for enabling or disabling Action Center in the cluster_config.json
file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
Enabling or disabling Apps
See the following configuration details for enabling or disabling Apps in the cluster_config.json
file:
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
Enabling or disabling AI Center
AI Center requires updating the enable
flag and an SQL database.
If you previously set a value for sql_connection_string_template_jdbc
in cluster_config.json
, then the default AI Center database name is AutomationSuite_AICenter
To change the default database name, you need to update the sql_connection_str
inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc
- If AI Center does not require an external Orchestrator, see the following configuration details for enabling or disabling AI Center in
cluster_config.json
"aicenter": {
"enabled": "true", //Set to "false" to disable the AICenter
"sql_connection_str": "" //Optional and only required to override the default database name
- If AI Center requires an external Orchestrator, see the following configuration details for enabling or disabling AI Center in
cluster_config.json
"aicenter": {
"enabled": "true", //Set to "false" to disable the AI Center
"orchestrator_url": "https://orchestrator.example.com", //Specify the Orchestrator URL for AI Center
"identity_server_url": "https://orchestrator.example.com/identity", //Specify the Identiy URL for AI Center
"orchestrator_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to the Orchestrator certificate
"identity_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to Identity certificate file
"metering_api_key": "test" //Specify the metering API key
Note:
metering_api_key
is the Document Understanding or AI Units API key from the AI Center cloud account.
To complete the installation, run the following post-installation command:
./configureUiPathAS.sh aicenter configure --installation-token <identity token>
Enabling or disabling Automation Ops
Automation Ops requires updating the enable
, then the default database name for Automation Ops is AutomationSuite_Platform
inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template
Note:
Automation Ops shares a database with the core platform, including Orchestrator. If you change the database here, you update the database for the core platform as well.
See the following configuration details for enabling or disabling Automation Ops in cluster_config.json
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
Enabling or disabling Data Service
Data Service requires updating the enable
, then the default database name is AutomationSuite_DataService
inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template
See the following configuration details for enabling or disabling Data Service in cluster_config.json
"dataservice": {
"enabled": "true", //Set to "false" to disable the Data Service,
Enabling or disabling Document Understanding
Document Understanding requires updating the enable
If you previously set a value for sql_connection_string_template_odbc
, then the default database name is AutomationSuite_DU_Datamanager
inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc
If you perform an offline installation, you need to download the offline bundle for Document Understanding as well. Before enabling Document Understanding, please refer to Install and Use Document Understanding.
See the following configuration details for enabling or disabling Document Understanding in cluster_config.json
"documentunderstanding": {
"enabled": "true", //Set to "false" to disable the Document Understanding
Enabling or disabling Insights
Insights requires updating the enable
, then the default database name is AutomationSuite_Insights
inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template
Insights has an optional SMTP configuration to enable receiving email notifications. Refer to Advanced installation experience for more details.
See the following configuration details for enabling or disabling Insights in cluster_config.json
"insights": {
"enabled": "true", //Set to "false" to disable the Insights,
Enabling or disabling Task Mining
Task Mining requires update the enable
flag and an SQL Database.
, then the default database name is AutomationSuite_Task_Mining
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads. Before enabling Task Mining, please refer Task Mining installation section Adding a dedicated agent node for Task Mining
See the following configuration details for enabling or disabling Task Mining in cluster_config.json
"task_mining": {
"enabled": "true", //Set to "false" to disable the Task Mining,
Uninstalling Task Mining - Un-taint a node
To uninstall Task Mining and free a tained node use the steps below:
- Check an actual taint using
kubectl describe node task-mining_nodename
command. - Run the command
kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-
- Check taint has disappeared using
command.
Enabling or disabling Test Manager
Test Manager requires updating the enable
, then the default database name is AutomationSuite_Test_Manager
inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template
See the following configuration details for enabling or disabling Test Manager in cluster_config.json
"test_manager": {
"enabled": "true", //Set to "false" to disable the Test Manager,
Important!
Once you update the configuration file, then proceed to Step 2.
Enabling or disabling Process Mining
To enable Process Mining, make the following changes to the cluster_config.json
file:
Enable the
processmining
flag. -
Configure the following connection string templates:
sql_connection_string_template_sqlalchemy_pyodbc
In multi-node HA-ready production installations, add a separate connection string for the second SQL Server. Note that in single-node evaluation installations, the seconds SQL Server is recommended. For instructions on how to configure the seconds SQL Server, see SQL requirements for Process Mining
"processmining": {
"enabled": true,
"sql_connection_str": "" // dotnet connection string
"sqlalchemy_pyodbc_sql_connection_str": "",
"warehouse": {
"sql_connection_str": "",
To disable Process Mining, disable the processmining
flag.
Enabling or disabling Automation Suite Robots
Before enabling Automation Suite Robots, make sure you meet the requirements.
To enable Automation Suite Robots, take the following steps:
- Enable the
asrobots
flag in thecluster_config.json
file. If you want to enable package caching, make sure to properly configure thepackagecaching
andpackagecachefolder
flags as well.
"asrobots": {
"enabled": Boolean,
"packagecaching": Boolean,
"packagecachefolder": String
Parameter | Default value | Description |
packagecaching | true | When set to true , robots use a local cache for package resolution. |
packagecachefolder | /uipath_asrobots_package_cache | The disk location on the serverless agent node where the packages are stored. |
Package caching optimizes your process runs and allows them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GB and should be allocated to a folder on the host machine filesystem of the dedicated nodes.
- If you use a multi-node HA-ready production setup, you must configure a specialized agent node for Automation Suite Robots. In single-node evaluation mode, an additional node is optional. For instructions, see Adding a dedicated agent node for Automation Suite Robots.
To disable Automation Suite Robots, disable the asrobots
flag in the cluster_config.json
file.
Step 2: Running the installer script to update the new product configuration
Once you update the cluster_config.json
, run the following command on the installer to update the service configuration.
- For online installations:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --accept-license-agreement
- For offline installations:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --install-type offline --accept-license-agreement
Updated 3 months ago
