Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.4.0
    • 2023.4.1
    • 2023.4.2
    • 2023.4.3
    • 2023.4.4
    • 2023.4.5
    • 2023.4.6
    • 2023.4.7
    • 2023.4.8
    • 2023.4.9
    • 2023.4.11
  • Automation Suite on EKS/AKS Release Notes
    • 2023.4.1
    • 2023.4.2
    • 2023.4.3
    • 2023.4.4
    • 2023.4.5
    • 2023.4.6
    • 2023.4.7
    • 2023.4.8
2023.4.7
Release date: June 27, 2024
General improvements​
This release brings various fixes and improvements.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Known issues​
Erratum - added October 17, 2024
In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
Erratum - added August 14, 2024
For AI Center and Task Mining, the ListBucket API prerequisite check fails when using an external objectstore. However, AI Center and Task Mining do not use the ListBucket API permission. We removed the unnecessary check in Automation Suite 2023.4.8.
Erratum - added June 25, 2024
Following an Automation Suite on AKS installation or upgrade, the backup setup does not work because of a failure to connect to Azure Government. You can fix the issue by taking the steps described in Automation Suite on EKS/AKS troubleshooting.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.4.7Automation Ops 2023.4.7AI Center 2023.4.7Action Center 2023.4.7
Task Mining 2023.4.7AI Computer Vision 2023.4.7Insights 2023.4.7Apps 2023.4.7
Process Mining 2023.4.7Document Understanding 2023.4.7Orchestrator 2023.4.8
Test Manager 2023.4.6
Data Service 2023.4.7
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.20.3
ArgoCD2.5.10
Prometheus2.42.0
Grafana10.2.3
Fluentd & Fluent-bitlogging-operator : 4.2.1
logging-operator-logging : 4.2.1
Gatekeeper3.11.0
Cert-Manager1.11.2
Velero6.2.0
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Stay updated
