2023.4.8
Release date: August 14, 2024
New RHEL versions support
We have expanded our OS support to include RHEL 8.10 and 9.2, alongside existing support for 8.6, 8.8, and 8.9 versions.
Images cleanup for in-cluster Docker registry
You can now effortlessly remove obsolete images post-upgrade. This capability is specifically designed for offline setups with an in-cluster Docker registry. For more details, see Automated: Offline upgrade and Manual: Offline upgrade.
Security enhancements
We continue to provide security updates and patches to address Common Vulnerabilities and Exposures (CVEs).
Bug fixes
- We have fixed an issue that prevented you from enabling SSO for ArgoCD due to a Dex image version discrepancy.
- For AI Center and Task Mining, the
ListBucket APIprerequisite check failed when using an external objectstore. However, AI Center and Task Mining do not use theListBucket APIpermission. We have removed the unnecessary check. - We have fixed an issue causing installation failures in certain conditions due to telemetry check errors. Previously, in case of failure, you had to manually set the telemetry check as optional and restart the installation. Now, a telemetry check failure only displays a warning and does not disrupt the installation process. This makes telemetry checks optional by default and ensures smooth, uninterrupted installations.
- We have fixed an issue that caused the support bundle to not include historical logs and to not upload to the configured external object store. This issue occured in offline environments using an external OCI registry.
Known issues
Grafana dashboard error
Erratum - added June 10, 2025: In multi-node (HA) setups, Grafana runs with two replicas, but there is no common data source between the replicas, causing issues in user session management. Errors like Dashboard not found and Invalid dashboard UID in the request appear in the Grafana dashboard.
As a workaround, since Grafana is not a critical application, you can reduce the replica count to one by performing the following steps:
Modify the helm parameter for the
fabric-installerapplication. This automatically triggers the sync operation forfabric-installerapplication.kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]'kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]' -
Sync the
rancher-monitoringapplication from ArgoCD UI.
We have fixed this issue in Automation Suite 2023.4.10.
Kube-proxy health check not working
Erratum - added April 15, 2025: The node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2023.4.12.
Email alerts configuration failure post upgrade
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
This issue is fixed in Automation Suite 2023.4.11.
Node maintenance issue in non-HA Redis
Erratum - added December 18, 2024: An issue causes the redis-cluster-0 pod to get stuck in the terminating state when you perform a node drain in non-HA Redis scenarios. To address the problem, you must force delete the pod using the following command:
kubectl -n redis-system delete pod redis-cluster-0 --force
We fixed the issue in Automation Suite 2023.4.10.
Insights annotation issue blocks installer
Erratum - added December 18, 2024: An Insights annotation issue blocks the Automation Suite installer. We fixed the issue in Automation Suite 2023.4.10.
RKE2 log collector runs indefinitely
Erratum - added December 18, 2024: The RKE2 log collector runs indefinitely for some system commands. We fixed the issue in Automation Suite 2023.4.10.
OSD PV resize does not persist after upgrade
If you resize the rook-ceph OSD PV, the new size does not persist following an Automation Suite upgrade.
Pods cannot communicate with FQDN in a proxy environment
Erratum - added October 17, 2024: In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
To fix the issue, see the Troubleshooting section.
Weak ciphers in TLS 1.2
Erratum - added August 29, 2024: We have identified certain vulnerabilities associated with the usage of weak ciphers in TLS 1.2. For details on how to mitigate the issue, see How to address weak ciphers in TLS 1.2.
Redis failures due to inconsistent password updates
Erratum - added October 17, 2024: An issue is causing Redis recovery job failures when you update the ArgoCD admin password directly through the UI without simultaneously updating the Kubernetes secrets as well. To prevent the issue, we highly recommend that each time you change the ArgoCD admin password via the UI, ensure that you update the Kubernetes secrets at the same time. For more details on how to properly update the ArgoCD admin password, refer to Troubleshooting.
Intermittent not ready reports from agent machines
Erratum - added October 17, 2024: An issue causes agent machines to intermittently report as not ready when the rke2-server service is shut down without executing the rke2-killall.sh script. We fixed this issue in Automation Suite 2023.4.9.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
Erratum - added October 17, 2024: Changed the bundled version of Test Manager to 2023.4.6.
| DISCOVER | BUILD | MANAGE | ENGAGE |
| Automation Hub 2023.4.8 | Automation Ops 2023.4.8 | AI Center 2023.4.8 | Action Center 2023.4.8 |
| Task Mining 2023.4.8 | AI Computer Vision 2023.4.7 | Insights 2023.4.8 | Apps 2023.4.8 |
| Process Mining 2023.4.8 | Document Understanding 2023.4.8 | Orchestrator 2023.4.9 | |
| Test Manager 2023.4.6 | |||
| Data Service 2023.4.8 |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.28.7 |
| ArgoCD | 2.10.9 |
| logging-operator | 4.6.0 |
| logging-operator-logging | 4.6.0 |
| gatekeeper | 3.16.0 |
| rook-ceph | 1.9.4 |
| prometheus-pushgateway | 2.12.0 |
| cert-manager | 1.14.5 |
| rancher-istio | 103.3.0-up1.21.1 |
| rancher-logging | 103.0.0-up3.17.10 |
| rancher-logging-crd | 103.0.0-up3.17.10 |
| rancher-monitoring-crd | 103.1.0-up45.31.1 |
| rancher-gatekeeper-crd | 103.1.0-up3.13.0 |
| rancher-gatekeeper | 103.1.0-up3.13.0 |
| rancher-monitoring | 103.1.0-up45.31.1 |
| longhorn | 1.5.5 |
| longhorn-crd | 1.1.100 |
| reloader | 1.0.95 |
| csi-driver-smb | 1.14.0 |
| velero | 6.2.0 |
| redis-operator | 7.4.2-12 |
| redis-cluster | 7.4.2-129 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- New RHEL versions support
- Images cleanup for in-cluster Docker registry
- Security enhancements
- Bug fixes
- Known issues
- Grafana dashboard error
- Kube-proxy health check not working
- Email alerts configuration failure post upgrade
- Node maintenance issue in non-HA Redis
- Insights annotation issue blocks installer
- RKE2 log collector runs indefinitely
- OSD PV resize does not persist after upgrade
- Weak ciphers in TLS 1.2
- Redis failures due to inconsistent password updates
- Intermittent not ready reports from agent machines
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
