Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.4.0
    • 2023.4.1
    • 2023.4.2
    • 2023.4.3
    • 2023.4.4
    • 2023.4.5
    • 2023.4.6
    • 2023.4.7
    • 2023.4.8
    • 2023.4.9
    • 2023.4.11
      • 2023.4.12+patch1
  • Automation Suite on EKS/AKS Release Notes
2023.4.12+patch1
Release date: June 30, 2025
About this patch​
This release applies a patch to Automation Suite 2023.4.12. The patch addresses some issues in Orchestrator. For more details, see the individual product release notes referenced in the Product versions section.
How to apply the patch​
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.4.12Automation Ops 2023.4.12AI Center 2023.4.12Action Center 2023.4.12
Task Mining 2023.4.12AI Computer Vision 2023.4.12Insights 2023.4.12Apps 2023.4.12
Process Mining 2023.4.12Document Understanding 2023.4.12Orchestrator 2023.4.15
Test Manager 2023.4.10
Data Service 2023.4.12
Internal third-party component versions​
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.31.4+rke2r1
ArgoCDv2.14.4
Grafana11.1.0
kube-logging/logging-operator5.2.0
kube-logging/config-reloaderv0.0.7
ceph19.2.0
rook-ceph1.16.1
prometheus-pushgatewayv3.0.0
cert-managerv1.17.1
rancher-istio105.4.0-up1.23.2
rancher-gatekeeper104.0.1-up3.13.0
rancher-monitoring105.1.3-up61.3.2
longhorn1.7.3
longhorn-crd1.1.100
csi-driver-smb1.16.0
velero1.15.2
redis-operatorv7.8.4-9
redis-clusterv7.8.4-95.focal
oauth2-proxyv7.8.1
  • About this patch​
  • How to apply the patch​
  • Deprecation timeline​
  • Bundling details​
  • Product versions​
  • Internal third-party component versions​
Connect
Stay updated
