  • Automation Suite on Linux Release Notes
    • 2023.4.0
    • 2023.4.1
    • 2023.4.2
    • 2023.4.3
    • 2023.4.4
    • 2023.4.5
    • 2023.4.6
    • 2023.4.7
    • 2023.4.8
    • 2023.4.9
    • 2023.4.11
  • Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Last updated Dec 4, 2025
2023.4.12
Release date: April 15, 2025
Enhanced telemetry
Enhanced Automation Suite with a high-level summarized usage telemetry feature, provided guidance on viewing the generated XML file, and added telemetry sharing with UiPath Support via the Customer Portal.
Istio HSTS enabled by default
To enhance security, Istio HSTS is now enabled by default.
Optional Docker pull secret value
The registries.docker.pull_secret_value field, which needs to be provided in the cluster_config.json file, is now optional.
Bug fixes
  • An issue was causing the node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, to not work for specific nodes such as GPU, task-mining, or as-robot. We have fixed the issue.
  • An issue was preventing the installer from automatically creating and validating the Orchestrator database. The issue occured even though the sql.create_db parameter was set to true in cluster_config.json. We have fixed the issue.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
AI Center 2023.4.12Action Center 2023.4.12
Task Mining 2023.4.12AI Computer Vision 2023.4.12Insights 2023.4.12Apps 2023.4.12
Document Understanding 2023.4.12Orchestrator 2023.4.13
  Test Manager 2023.4.10
Internal third-party component versions
This Automation Suite release bundles the following internal components:
Component
Version
RKE2
1.31.4+rke2r1
ArgoCD
v2.14.4
Grafana
11.1.0
kube-logging/logging-operator
5.2.0
kube-logging/config-reloader
v0.0.7
ceph
19.2.0
rook-ceph
1.16.1
prometheus-pushgateway
v3.0.0
cert-manager
v1.17.1
rancher-istio
105.4.0-up1.23.2
rancher-gatekeeper
104.0.1-up3.13.0
rancher-monitoring
105.1.3-up61.3.2
longhorn
1.7.3
longhorn-crd
1.1.100
csi-driver-smb
1.16.0
velero
1.15.2
redis-operator
v7.8.4-9
redis-cluster
v7.8.4-95.focal
oauth2-proxy
v7.8.1
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
