- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Solutions for unauthenticated network access to the ArgoCD repo-server and Redis in Automation Suite, with a manual NetworkPolicy mitigation procedure.
A vulnerability affecting the ArgoCD repo-server component was recently published and is not fixed by ArgoCD at this moment.
The ArgoCD repo-server (port 8081) and ArgoCD Redis are reachable from any pod in the cluster network, because no NetworkPolicy restricts ingress to these components by default. As a result, any pod within the cluster network can connect to them directly, since ArgoCD does not require authentication for these internal components. For details, refer to GHSA-47m3-95c7-g2g8.
To mitigate the issue, you must manually apply the NetworkPolicy described in the Solution section on this page.
Prerequisites
- Run this procedure from a host with
kubectlaccess to the cluster. - The procedure assumes the default Automation Suite
argocdnamespace. If ArgoCD uses a different namespace, setARGOCD_NSbefore running the script. - This mitigation relies on Kubernetes NetworkPolicy enforcement. Automation Suite supported clusters use a compatible CNI (Container Network Interface) configuration.
Solution
Run the following script. It detects your ArgoCD release and Redis mode (standalone or high availability, HA), and applies the matching NetworkPolicy automatically:
export ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')" test -n "$ARGOCD_RELEASE" || { echo "Cannot detect Argo CD Helm release"; exit 1; } if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi echo "Argo CD namespace: $ARGOCD_NS" echo "Argo CD release: $ARGOCD_RELEASE" echo "Redis mode: $REDIS_MODE" cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-repo-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-applicationset-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-notifications-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 8081 - from: - namespaceSelector: {} ports: - protocol: TCP port: 8084 EOF if [ "$REDIS_MODE" = "ha" ]; then cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy ports: - protocol: TCP port: 6379 - protocol: TCP port: 26379 --- apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-haproxy-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy app.kubernetes.io/name: argocd-redis-ha-haproxy policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 EOF else cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-redis app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 - from: - namespaceSelector: {} ports: - protocol: TCP port: 9121 EOF fiexport ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')" test -n "$ARGOCD_RELEASE" || { echo "Cannot detect Argo CD Helm release"; exit 1; } if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi echo "Argo CD namespace: $ARGOCD_NS" echo "Argo CD release: $ARGOCD_RELEASE" echo "Redis mode: $REDIS_MODE" cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-repo-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-applicationset-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-notifications-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 8081 - from: - namespaceSelector: {} ports: - protocol: TCP port: 8084 EOF if [ "$REDIS_MODE" = "ha" ]; then cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy ports: - protocol: TCP port: 6379 - protocol: TCP port: 26379 --- apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-haproxy-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy app.kubernetes.io/name: argocd-redis-ha-haproxy policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 EOF else cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-redis app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 - from: - namespaceSelector: {} ports: - protocol: TCP port: 9121 EOF fi
Verify
Run the following commands to confirm the mitigation was applied successfully:
kubectl -n "$ARGOCD_NS" get networkpolicy
kubectl -n "$ARGOCD_NS" get pods
kubectl get applications.argoproj.io -A
Confirm the following:
argocd-repo-server-manual-mitigationexists.- For Redis HA,
argocd-redis-ha-server-manual-mitigationandargocd-redis-ha-haproxy-manual-mitigationexist. - For standalone Redis,
argocd-redis-manual-mitigationexists. - ArgoCD pods are
RunningorCompleted. - ArgoCD Applications remain
SyncedandHealthy.
Confirm Mitigation
Run these checks after applying the policies. They verify that required ArgoCD traffic still works and disallowed traffic is blocked.
Run the following script:
export ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="${ARGOCD_RELEASE:-$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')}" if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi SERVER_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.name}')" APPSET_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-applicationset-controller -o jsonpath='{.items[0].metadata.name}' 2>/dev/null || true)" FAILED_CHECKS="" tcp_check() { pod="$1" host="$2" port="$3" expected="$4" name="$5" code="$(kubectl -n "$ARGOCD_NS" exec "$pod" -- sh -c ' host="$1" port="$2" if command -v nc >/dev/null 2>&1; then timeout 5 nc -z -w 3 "$host" "$port" >/dev/null 2>&1 printf "%s\n" "$?" elif command -v bash >/dev/null 2>&1; then timeout 5 bash -c "</dev/tcp/${host}/${port}" >/dev/null 2>&1 printf "%s\n" "$?" else printf "%s\n" "NO_TCP_TOOL" fi ' sh "$host" "$port" 2>/dev/null | tail -n 1)" if [ "$expected" = "allow" ] && [ "$code" = "0" ]; then return elif [ "$expected" = "deny" ] && [ "$code" != "0" ] && [ "$code" != "NO_TCP_TOOL" ] && [ -n "$code" ]; then return else FAILED_CHECKS="${FAILED_CHECKS} - ${name}: expected ${expected}, got exit code ${code}" fi } tcp_check "$SERVER_POD" argocd-repo-server 8081 allow "argocd-server to repo-server:8081" if [ "$REDIS_MODE" = "ha" ]; then HAPROXY_POD="$(kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis-ha-haproxy 6379 allow "argocd-server to redis-ha-haproxy:6379" tcp_check "$HAPROXY_POD" argocd-redis-ha 6379 allow "redis-ha-haproxy to redis-ha:6379" tcp_check "$HAPROXY_POD" argocd-repo-server 8081 deny "redis-ha-haproxy to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis-ha-haproxy 6379 deny "applicationset-controller to redis-ha-haproxy:6379" fi else REDIS_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-redis -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis 6379 allow "argocd-server to redis:6379" tcp_check "$REDIS_POD" argocd-repo-server 8081 deny "redis to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis 6379 deny "applicationset-controller to redis:6379" fi fi if [ -z "$FAILED_CHECKS" ]; then echo "MITIGATION CHECK: PASS" else echo "MITIGATION CHECK: FAIL" echo "$FAILED_CHECKS" exit 1 fiexport ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="${ARGOCD_RELEASE:-$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')}" if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi SERVER_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.name}')" APPSET_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-applicationset-controller -o jsonpath='{.items[0].metadata.name}' 2>/dev/null || true)" FAILED_CHECKS="" tcp_check() { pod="$1" host="$2" port="$3" expected="$4" name="$5" code="$(kubectl -n "$ARGOCD_NS" exec "$pod" -- sh -c ' host="$1" port="$2" if command -v nc >/dev/null 2>&1; then timeout 5 nc -z -w 3 "$host" "$port" >/dev/null 2>&1 printf "%s\n" "$?" elif command -v bash >/dev/null 2>&1; then timeout 5 bash -c "</dev/tcp/${host}/${port}" >/dev/null 2>&1 printf "%s\n" "$?" else printf "%s\n" "NO_TCP_TOOL" fi ' sh "$host" "$port" 2>/dev/null | tail -n 1)" if [ "$expected" = "allow" ] && [ "$code" = "0" ]; then return elif [ "$expected" = "deny" ] && [ "$code" != "0" ] && [ "$code" != "NO_TCP_TOOL" ] && [ -n "$code" ]; then return else FAILED_CHECKS="${FAILED_CHECKS} - ${name}: expected ${expected}, got exit code ${code}" fi } tcp_check "$SERVER_POD" argocd-repo-server 8081 allow "argocd-server to repo-server:8081" if [ "$REDIS_MODE" = "ha" ]; then HAPROXY_POD="$(kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis-ha-haproxy 6379 allow "argocd-server to redis-ha-haproxy:6379" tcp_check "$HAPROXY_POD" argocd-redis-ha 6379 allow "redis-ha-haproxy to redis-ha:6379" tcp_check "$HAPROXY_POD" argocd-repo-server 8081 deny "redis-ha-haproxy to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis-ha-haproxy 6379 deny "applicationset-controller to redis-ha-haproxy:6379" fi else REDIS_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-redis -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis 6379 allow "argocd-server to redis:6379" tcp_check "$REDIS_POD" argocd-repo-server 8081 deny "redis to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis 6379 deny "applicationset-controller to redis:6379" fi fi if [ -z "$FAILED_CHECKS" ]; then echo "MITIGATION CHECK: PASS" else echo "MITIGATION CHECK: FAIL" echo "$FAILED_CHECKS" exit 1 fiExpected result:
Rollback
If required, take the following steps to remove the mitigation:
Delete the manual mitigation policies:
kubectl -n "$ARGOCD_NS" delete networkpolicy \ argocd-repo-server-manual-mitigation \ argocd-redis-manual-mitigation \ argocd-redis-ha-server-manual-mitigation \ argocd-redis-ha-haproxy-manual-mitigation \ --ignore-not-foundkubectl -n "$ARGOCD_NS" delete networkpolicy \ argocd-repo-server-manual-mitigation \ argocd-redis-manual-mitigation \ argocd-redis-ha-server-manual-mitigation \ argocd-redis-ha-haproxy-manual-mitigation \ --ignore-not-found -
Confirm the rollback completed successfully:
kubectl -n "$ARGOCD_NS" get networkpolicy kubectl -n "$ARGOCD_NS" get pods kubectl get applications.argoproj.io -Akubectl -n "$ARGOCD_NS" get networkpolicy kubectl -n "$ARGOCD_NS" get pods kubectl get applications.argoproj.io -AConfirm the following:
- The manual mitigation policies are removed.
- ArgoCD pods remain
SyncedandHealthy.
