# Configuring log rules
> Robot logs capture diagnostic and execution logs. You can configure the conditions for which Robot logs are ingested by Insights. For example, you only want to capture logs for Processes that include a specific name.
## Overview
For details, refer to [Robot logs](https://docs.uipath.com/robot/docs/robot-logs).
## Configure Log Rules
You can configure the Orchestrator settings in the `nlog.custom.config` file. To modify the settings, take the following steps:
1. Place the new log rules inside the `nlog.custom.config` file. Check the following details for an example:
     "10_Robot_Insights": {
       "logger": "Robot.*",
       "ruleName": "insightsRobotLogsRule",
       "minLevel": "Info",
       "writeTo": "insightsRobotLogs",
       "enabled": false,
       "final": false,
       "filters": {
         "defaultAction": "Ignore",
         "conditions": [
             "condition": "level >= LogLevel.Error or ends-with('${message}', ' execution ended')",
             "action": "Log"
2. Use the [Orchestrator Configurator Tool](https://docs.uipath.com/automation-suite/automation-suite/2023.10/installation-guide/orchestrator-configurator-tool) to update the configuration. Use the following command to merge the keys from the custom `nlog.custom.config` file with the settings already available in the `orchestrator-customconfig` configuration map.
    ./orchestrator-configurator.sh -l nlog.custom.config
    This command does not remove any existing settings.
## Log Rules Example
In the following example, we are only sending logs that exceed a certain level or contain the message that the execution has ended:
    "minLevel": "Info",
    "enabled": false,
    "final": false,
    "filters": {
      "conditions": [
          "action": "Log"
