- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Solutions for unauthenticated network access to the ArgoCD repo-server and Redis in Automation Suite, with a manual NetworkPolicy mitigation procedure.
A vulnerability affecting the ArgoCD repo-server component was recently published and is not fixed by ArgoCD at this moment.
The ArgoCD repo-server (port 8081) and ArgoCD Redis are reachable from any pod in the cluster network, because no NetworkPolicy restricts ingress to these components by default. As a result, any pod within the cluster network can connect to them directly, since ArgoCD does not require authentication for these internal components. For details, refer to GHSA-47m3-95c7-g2g8.
To mitigate the issue, you must manually apply the NetworkPolicy described in the Solution section on this page.
Prerequisites
- Run this procedure from a host with
kubectlaccess to the cluster. - The procedure assumes the default Automation Suite
argocdnamespace. If ArgoCD uses a different namespace, setARGOCD_NSbefore running the script. - This mitigation relies on Kubernetes NetworkPolicy enforcement, which is provided by the CNI (Container Network Interface) plugin. Some CNIs, such as the Amazon VPC CNI, do not enforce network policies by default; in that case, the applied policies have no effect. Make sure network policy enforcement is enabled in your cluster. For instructions, refer to the official documentation of your CNI.
Solution
Run the following script. It detects your ArgoCD release and Redis mode (standalone or high availability, HA), and applies the matching NetworkPolicy automatically:
export ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')" test -n "$ARGOCD_RELEASE" || { echo "Cannot detect Argo CD Helm release"; exit 1; } if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi echo "Argo CD namespace: $ARGOCD_NS" echo "Argo CD release: $ARGOCD_RELEASE" echo "Redis mode: $REDIS_MODE" cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-repo-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-applicationset-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-notifications-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 8081 - from: - namespaceSelector: {} ports: - protocol: TCP port: 8084 EOF if [ "$REDIS_MODE" = "ha" ]; then cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy ports: - protocol: TCP port: 6379 - protocol: TCP port: 26379 --- apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-haproxy-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy app.kubernetes.io/name: argocd-redis-ha-haproxy policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 EOF else cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-redis app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 - from: - namespaceSelector: {} ports: - protocol: TCP port: 9121 EOF fiexport ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')" test -n "$ARGOCD_RELEASE" || { echo "Cannot detect Argo CD Helm release"; exit 1; } if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi echo "Argo CD namespace: $ARGOCD_NS" echo "Argo CD release: $ARGOCD_RELEASE" echo "Redis mode: $REDIS_MODE" cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-repo-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-applicationset-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-notifications-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 8081 - from: - namespaceSelector: {} ports: - protocol: TCP port: 8084 EOF if [ "$REDIS_MODE" = "ha" ]; then cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-server-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha - podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy ports: - protocol: TCP port: 6379 - protocol: TCP port: 26379 --- apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-ha-haproxy-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: release: ${ARGOCD_RELEASE} app: redis-ha-haproxy app.kubernetes.io/name: argocd-redis-ha-haproxy policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 EOF else cat <<EOF | kubectl apply -f - apiVersion: networking.k8s.io/v1 kind: NetworkPolicy metadata: name: argocd-redis-manual-mitigation namespace: ${ARGOCD_NS} spec: podSelector: matchLabels: app.kubernetes.io/name: argocd-redis app.kubernetes.io/instance: ${ARGOCD_RELEASE} policyTypes: - Ingress ingress: - from: - podSelector: matchLabels: app.kubernetes.io/name: argocd-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-repo-server app.kubernetes.io/instance: ${ARGOCD_RELEASE} - podSelector: matchLabels: app.kubernetes.io/name: argocd-application-controller app.kubernetes.io/instance: ${ARGOCD_RELEASE} ports: - protocol: TCP port: 6379 - from: - namespaceSelector: {} ports: - protocol: TCP port: 9121 EOF fi
Verify
Run the following commands to confirm the mitigation was applied successfully:
kubectl -n "$ARGOCD_NS" get networkpolicy
kubectl -n "$ARGOCD_NS" get pods
kubectl get applications.argoproj.io -A
Confirm the following:
argocd-repo-server-manual-mitigationexists.- For Redis HA,
argocd-redis-ha-server-manual-mitigationandargocd-redis-ha-haproxy-manual-mitigationexist. - For standalone Redis,
argocd-redis-manual-mitigationexists. - ArgoCD pods are
RunningorCompleted. - ArgoCD Applications remain
SyncedandHealthy.
Confirm Mitigation
Run these checks after applying the policies. They verify that required ArgoCD traffic still works and disallowed traffic is blocked.
Run the following script:
export ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="${ARGOCD_RELEASE:-$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')}" if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi SERVER_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.name}')" APPSET_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-applicationset-controller -o jsonpath='{.items[0].metadata.name}' 2>/dev/null || true)" FAILED_CHECKS="" tcp_check() { pod="$1" host="$2" port="$3" expected="$4" name="$5" code="$(kubectl -n "$ARGOCD_NS" exec "$pod" -- sh -c ' host="$1" port="$2" if command -v nc >/dev/null 2>&1; then timeout 5 nc -z -w 3 "$host" "$port" >/dev/null 2>&1 printf "%s\n" "$?" elif command -v bash >/dev/null 2>&1; then timeout 5 bash -c "</dev/tcp/${host}/${port}" >/dev/null 2>&1 printf "%s\n" "$?" else printf "%s\n" "NO_TCP_TOOL" fi ' sh "$host" "$port" 2>/dev/null | tail -n 1)" if [ "$expected" = "allow" ] && [ "$code" = "0" ]; then return elif [ "$expected" = "deny" ] && [ "$code" != "0" ] && [ "$code" != "NO_TCP_TOOL" ] && [ -n "$code" ]; then return else FAILED_CHECKS="${FAILED_CHECKS} - ${name}: expected ${expected}, got exit code ${code}" fi } tcp_check "$SERVER_POD" argocd-repo-server 8081 allow "argocd-server to repo-server:8081" if [ "$REDIS_MODE" = "ha" ]; then HAPROXY_POD="$(kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis-ha-haproxy 6379 allow "argocd-server to redis-ha-haproxy:6379" tcp_check "$HAPROXY_POD" argocd-redis-ha 6379 allow "redis-ha-haproxy to redis-ha:6379" tcp_check "$HAPROXY_POD" argocd-repo-server 8081 deny "redis-ha-haproxy to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis-ha-haproxy 6379 deny "applicationset-controller to redis-ha-haproxy:6379" fi else REDIS_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-redis -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis 6379 allow "argocd-server to redis:6379" tcp_check "$REDIS_POD" argocd-repo-server 8081 deny "redis to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis 6379 deny "applicationset-controller to redis:6379" fi fi if [ -z "$FAILED_CHECKS" ]; then echo "MITIGATION CHECK: PASS" else echo "MITIGATION CHECK: FAIL" echo "$FAILED_CHECKS" exit 1 fiexport ARGOCD_NS="${ARGOCD_NS:-argocd}" export ARGOCD_RELEASE="${ARGOCD_RELEASE:-$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.labels.app\.kubernetes\.io/instance}')}" if kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" --no-headers 2>/dev/null | grep -q .; then REDIS_MODE=ha else REDIS_MODE=standalone fi SERVER_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-server -o jsonpath='{.items[0].metadata.name}')" APPSET_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-applicationset-controller -o jsonpath='{.items[0].metadata.name}' 2>/dev/null || true)" FAILED_CHECKS="" tcp_check() { pod="$1" host="$2" port="$3" expected="$4" name="$5" code="$(kubectl -n "$ARGOCD_NS" exec "$pod" -- sh -c ' host="$1" port="$2" if command -v nc >/dev/null 2>&1; then timeout 5 nc -z -w 3 "$host" "$port" >/dev/null 2>&1 printf "%s\n" "$?" elif command -v bash >/dev/null 2>&1; then timeout 5 bash -c "</dev/tcp/${host}/${port}" >/dev/null 2>&1 printf "%s\n" "$?" else printf "%s\n" "NO_TCP_TOOL" fi ' sh "$host" "$port" 2>/dev/null | tail -n 1)" if [ "$expected" = "allow" ] && [ "$code" = "0" ]; then return elif [ "$expected" = "deny" ] && [ "$code" != "0" ] && [ "$code" != "NO_TCP_TOOL" ] && [ -n "$code" ]; then return else FAILED_CHECKS="${FAILED_CHECKS} - ${name}: expected ${expected}, got exit code ${code}" fi } tcp_check "$SERVER_POD" argocd-repo-server 8081 allow "argocd-server to repo-server:8081" if [ "$REDIS_MODE" = "ha" ]; then HAPROXY_POD="$(kubectl -n "$ARGOCD_NS" get pod -l "release=${ARGOCD_RELEASE},app=redis-ha-haproxy" -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis-ha-haproxy 6379 allow "argocd-server to redis-ha-haproxy:6379" tcp_check "$HAPROXY_POD" argocd-redis-ha 6379 allow "redis-ha-haproxy to redis-ha:6379" tcp_check "$HAPROXY_POD" argocd-repo-server 8081 deny "redis-ha-haproxy to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis-ha-haproxy 6379 deny "applicationset-controller to redis-ha-haproxy:6379" fi else REDIS_POD="$(kubectl -n "$ARGOCD_NS" get pod -l app.kubernetes.io/name=argocd-redis -o jsonpath='{.items[0].metadata.name}')" tcp_check "$SERVER_POD" argocd-redis 6379 allow "argocd-server to redis:6379" tcp_check "$REDIS_POD" argocd-repo-server 8081 deny "redis to repo-server:8081" if [ -n "$APPSET_POD" ]; then tcp_check "$APPSET_POD" argocd-redis 6379 deny "applicationset-controller to redis:6379" fi fi if [ -z "$FAILED_CHECKS" ]; then echo "MITIGATION CHECK: PASS" else echo "MITIGATION CHECK: FAIL" echo "$FAILED_CHECKS" exit 1 fiExpected result:
Rollback
If required, take the following steps to remove the mitigation:
Delete the manual mitigation policies:
kubectl -n "$ARGOCD_NS" delete networkpolicy \ argocd-repo-server-manual-mitigation \ argocd-redis-manual-mitigation \ argocd-redis-ha-server-manual-mitigation \ argocd-redis-ha-haproxy-manual-mitigation \ --ignore-not-foundkubectl -n "$ARGOCD_NS" delete networkpolicy \ argocd-repo-server-manual-mitigation \ argocd-redis-manual-mitigation \ argocd-redis-ha-server-manual-mitigation \ argocd-redis-ha-haproxy-manual-mitigation \ --ignore-not-found -
Confirm the rollback completed successfully:
kubectl -n "$ARGOCD_NS" get networkpolicy kubectl -n "$ARGOCD_NS" get pods kubectl get applications.argoproj.io -Akubectl -n "$ARGOCD_NS" get networkpolicy kubectl -n "$ARGOCD_NS" get pods kubectl get applications.argoproj.io -AConfirm the following:
- The manual mitigation policies are removed.
- ArgoCD pods remain
SyncedandHealthy.
