- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- How to forward application logs to Splunk
- How to uninstall Automation Suite
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Collect Document Understanding usage data when using in-cluster objectstore (Ceph) in Automation Suite on EKS/AKS.
This section explains how to collect Document Understanding (DU) usage data when using in-cluster objectstore (Ceph).
Take the following steps:
- Before running the DU collector script, make sure to update the following values:
<REGISTRY>:- Use
localhost:30071for offline deployments. - Use
registry.uipath.comfor online deployments. - Use your external registry URL for private registries.
- Use
<TAG>: Openversions.jsonand locate thesf-k8-utils-rhelimage tag. Use this tag to replace<TAG>in the script.
- Run the DU usage collector script after updating the values, as follows:
NAMESPACE="rook-ceph" POD_NAME="du-usage-collector" SECRET_NAME="ceph-object-store-secret" LOCAL_TAR="du-usage.tar.gz" MOUNTED_SECRET_PATH="/rook-secret" TARGET_PATH="aistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001" BUCKET_NAME="ai-storage" IMAGE="<REGISTRY>/uipath/sf-k8-utils-rhel:<TAG>" echo "[*] Removing pod $POD_NAME in namespace $NAMESPACE..." kubectl delete pod "$POD_NAME" -n "$NAMESPACE" --ignore-not-found=true echo "[*] Creating pod $POD_NAME in namespace $NAMESPACE..." kubectl apply -n "$NAMESPACE" -f - <<EOF apiVersion: v1 kind: Pod metadata: name: $POD_NAME namespace: $NAMESPACE spec: restartPolicy: Never containers: - name: sleep image: $IMAGE command: ["bash", "-c", "echo 'Main container started, sleeping...'; sleep 3600"] volumeMounts: - name: output mountPath: /output initContainers: - name: du-usage-collector image: $IMAGE command: ["/bin/bash", "-c"] args: - | set -euo pipefail echo "[*] Extracting Ceph secret values..." ACCESS_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_ACCESSKEY) SECRET_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_SECRETKEY) HOST=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_INTERNAL_SERVICE) PORT=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_PORT) export AWS_ACCESS_KEY_ID=\$ACCESS_KEY export AWS_SECRET_ACCESS_KEY=\$SECRET_KEY echo "[*] Syncing from s3://$BUCKET_NAME/$TARGET_PATH ..." mkdir -p /tmp/download s3cmd sync s3://$BUCKET_NAME/$TARGET_PATH/ /tmp/download/ \ --host=\$HOST:\$PORT --host-bucket= --no-ssl --no-check-certificate echo "[*] Creating archive..." mkdir -p /output tar -czf /output/du-usage.tar.gz -C /tmp/download . echo "[-] Archive ready at /output/du-usage.tar.gz" volumeMounts: - name: rook-secret mountPath: $MOUNTED_SECRET_PATH readOnly: true - name: output mountPath: /output volumes: - name: rook-secret secret: secretName: $SECRET_NAME optional: false - name: output emptyDir: {} EOF echo "[*] Waiting for pod to be Running..." for i in {1..30}; do phase=$(kubectl get pod "$POD_NAME" -n "$NAMESPACE" -o jsonpath="{.status.phase}") if [[ "$phase" == "Running" ]]; then echo "Pod is Running." break fi echo "[$i] Still waiting..." sleep 5 done echo -e "\nArchive will be saved as: $LOCAL_TAR\n\n" echo "[*] Copying archive from pod to local..." kubectl cp "$NAMESPACE/$POD_NAME:/output/du-usage.tar.gz" "$LOCAL_TAR"NAMESPACE="rook-ceph" POD_NAME="du-usage-collector" SECRET_NAME="ceph-object-store-secret" LOCAL_TAR="du-usage.tar.gz" MOUNTED_SECRET_PATH="/rook-secret" TARGET_PATH="aistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001" BUCKET_NAME="ai-storage" IMAGE="<REGISTRY>/uipath/sf-k8-utils-rhel:<TAG>" echo "[*] Removing pod $POD_NAME in namespace $NAMESPACE..." kubectl delete pod "$POD_NAME" -n "$NAMESPACE" --ignore-not-found=true echo "[*] Creating pod $POD_NAME in namespace $NAMESPACE..." kubectl apply -n "$NAMESPACE" -f - <<EOF apiVersion: v1 kind: Pod metadata: name: $POD_NAME namespace: $NAMESPACE spec: restartPolicy: Never containers: - name: sleep image: $IMAGE command: ["bash", "-c", "echo 'Main container started, sleeping...'; sleep 3600"] volumeMounts: - name: output mountPath: /output initContainers: - name: du-usage-collector image: $IMAGE command: ["/bin/bash", "-c"] args: - | set -euo pipefail echo "[*] Extracting Ceph secret values..." ACCESS_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_ACCESSKEY) SECRET_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_SECRETKEY) HOST=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_INTERNAL_SERVICE) PORT=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_PORT) export AWS_ACCESS_KEY_ID=\$ACCESS_KEY export AWS_SECRET_ACCESS_KEY=\$SECRET_KEY echo "[*] Syncing from s3://$BUCKET_NAME/$TARGET_PATH ..." mkdir -p /tmp/download s3cmd sync s3://$BUCKET_NAME/$TARGET_PATH/ /tmp/download/ \ --host=\$HOST:\$PORT --host-bucket= --no-ssl --no-check-certificate echo "[*] Creating archive..." mkdir -p /output tar -czf /output/du-usage.tar.gz -C /tmp/download . echo "[-] Archive ready at /output/du-usage.tar.gz" volumeMounts: - name: rook-secret mountPath: $MOUNTED_SECRET_PATH readOnly: true - name: output mountPath: /output volumes: - name: rook-secret secret: secretName: $SECRET_NAME optional: false - name: output emptyDir: {} EOF echo "[*] Waiting for pod to be Running..." for i in {1..30}; do phase=$(kubectl get pod "$POD_NAME" -n "$NAMESPACE" -o jsonpath="{.status.phase}") if [[ "$phase" == "Running" ]]; then echo "Pod is Running." break fi echo "[$i] Still waiting..." sleep 5 done echo -e "\nArchive will be saved as: $LOCAL_TAR\n\n" echo "[*] Copying archive from pod to local..." kubectl cp "$NAMESPACE/$POD_NAME:/output/du-usage.tar.gz" "$LOCAL_TAR" - After retrieving the archive, delete the pod:
kubectl delete pod "$POD_NAME" -n "$NAMESPACE"kubectl delete pod "$POD_NAME" -n "$NAMESPACE"
The du-usage.tar.gz file contains the DU usage data.
