# Delete specific group
> API reference for deleting a specific group from an organization by organization and group ID in Automation Suite.
Deletes the specified group in an organization, based on the organization and group ID.
## API endpoint
`DELETE` `https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}`
## Scopes
Requires the following scopes:
* `PM.Group`
* `PM.Group.Write`
## Request headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described [here](https://docs.uipath.com/automation-suite/automation-suite/2023.10/api-guide/authentication-methods#authentication-methods).
## Path parameters
| Parameter | Data type | Description |
| `partitionGlobalId` | String | **Required.**The ID of the organization you want to delete the group from. |
| `groupId` | String | **Required.**The ID of the group you want to delete. |
## Responses
### 204 Success
The indicated group is deleted from the organization.
## Example request
Let's say you gathered all the information needed to build the API call.
* Your `{baseURL}` is: `https://{yourDomain}/{organizationName}/{tenantName}/`
* Your `{access_token}` is: `1234` (for length considerations).
* The `{partitionGlobalId}` is: `magic-7`
* The `{groupId}` is: `2512`
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Group/magic-7/2512' \
