- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Activating your license
Activate, update, or deactivate your Automation Suite license at the organization or host level.
Managing licenses in an online instance
If your instance of Automation Suite has access to the internet, follow the instructions in this section to activate, update, or deactivate your license.
These procedures are administered either at the organization level by an organization admin (for organization licensing), or at the host portal level by a system admin (for host licensing).
Activating your license online
If you already have a UiPath® license, contact UiPath to request a new license code with the same quantities for use in Automation Suite.
Log in to the organization as an organization administrator or to the host portal as a system administrator.
Make sure that the organization name (for organization licensing) or Host (for host licensing) is selected in the pane on the left and then select Licenses.
Select Activate License and then Online Activation.
The Activate License Online panel opens from the right of the window.
The Account ID field is automatically populated with the unique identifier of your Automation Suite instance.
In the License Code field, enter the license key you received from UiPath.
Select Activate.
Updating your license online
Whenever your license changes - for example when new licenses are added, or when you renew your license - you must perform a license update from Automation Suite.
Select Update License in the top right and select Online Activation.
The Update License Online panel opens from the right of the window and the Account ID and License Code fields are already filled in with your information.
Select Update.
UiPath automatically checks your license status and synchronizes any changes. When finished, a success message appears in a tooltip at the top right of the page and the Licenses page refreshes to display the updated information.
Deactivating your license online
Select Deactivate License and select Online Deactivation.
In the confirmation dialog, select Remove to confirm the action.
A tooltip appears in the top right of the screen, confirming that the license has been deactivated.
On the Licenses page, the state changes to Unlicensed.
Managing licenses in an offline instance
If your instance of Automation Suite does not access to the internet, follow the instructions in this section to activate, update, or deactivate your license.
Activating your license offline
If you already have a UiPath license, contact UiPath to request a new license code with the same quantities for use in Automation Suite.
Obtaining the license request file:
Select Activate License and then select Offline Activation.
The Activate License Offline panel opens at the right of the window.
Fill in the License Code field with your license key.
Under Do you have a license file? select No.
Note:If you already have a license file, skip to the sub-section Activating the license.
Under step 1, select Download to generate and save a license request file. A download begins for the file Activation Request.txt.
Move this file to a different machine which does have internet access.
Obtaining the license file:
Follow these instructions on a machine with internet access.
Copy the license request file Activation Request.txt to the machine.
In a web browser, go to the Activation Portal.
Select Upload from File and choose the Activation Request.txt file to upload it.
The file contents is added to the text box.
Select Generate License File.
A download begins for the file license.txt.
Transfer the file license.txt back to the Automation Suite machine.
Activating the license:
Log in to the organization as an organization administrator or to the host portal as a system administrator, and navigate to the Licenses page.
Under Do you have a license file? select Yes.
Under Upload License, select Choose File and select the license.txt file.
Select Activate. Your Automation Suite instance now appears as licensed and the Licenses page shows your available licenses.
Updating your license offline
Whenever your license changes - for example when new licenses are added, or when you renew your license - you must perform a license update from the UiPath platform.
If your UiPath installation does not have access to the internet, the process for updating the license is the same as the one for activating the license offline.
Deactivating your license offline
Obtaining the license deactivation file:
Select Deactivate License and then select Offline Deactivation.
The Deactivate License panel opens at the right of the window.
Under step 1, select Download to generate and save a license deactivation file.
A download begins for the file Deactivation Request.txt.
Deactivating the license:
Copy the file Deactivation Request.txt to the machine.
Select the Deactivate your License tab.
Select Upload from File and choose the Deactivation Request.txt file to upload it.
