# Cleaning up the Task Mining database
> This page describes the necessary maintenance tasks for the Task Mining databases.
## Overview
The default Task Mining database, named `[AutomationSuite_Task_Mining]`, uses a single schema `[tddiscovery]` for data storage. Primarily, Task Mining stores data in the object store, reducing the need of frequent database maintenance. If required, you can use the `Remove_Active_History.sql` database maintenance script to periodically clean up the following database table:
* `[AutomationSuite_Task_Mining].[tddiscovery].[ActivityHistory]`
:::important
Ensure to back up the Task Mining database `[AutomationSuite_Task_Mining]` before executing any scripts.
## Prerequisites
The following prerequisites are assumed:
* You have access to the `[AutomationSuite_Task_Mining]` database with the required permissions.
## Remove_Active_History.sql script
CREATE PROCEDURE [tddiscovery].[Delete_TaskMining_ActivityHistory]
   @CutoffTimeStamp datetime2,
   @BatchSize INT = 10000
AS
BEGIN
   DECLARE @total_deleted_items BIGINT = 0;
   SET NOCOUNT ON;
   -- delete ActivityHistoryItems
   DECLARE @Deleted_Rows_ActivityHistoryItems INT = @BatchSize;
   WHILE(@Deleted_Rows_ActivityHistoryItems = @BatchSize)
   BEGIN
     DELETE TOP(@BatchSize) FROM [tddiscovery].[ActivityHistory] WHERE At <= @CutoffTimeStamp;
     SET @Deleted_Rows_ActivityHistoryItems = @@ROWCOUNT;
     SET @total_deleted_items = @Deleted_Rows_ActivityHistoryItems + @total_deleted_items;
   END;
   PRINT('The script executed successfully!');
   PRINT('Total deleted rows from [tddiscovery].[ActivityHistory]: ' + CONVERT(NVARCHAR, @total_deleted_items));
END;
GO
## Steps
1. Run the `Remove_Active_History.sql` database maintenance script to create the `Delete_TaskMining_ActivityHistory` Stored Procedure.
   :::note
   Always use the most recent version of the Stored Procedure.
   It is strongly recommended to archive previously executed SQL Stored Procedures by renaming the Stored Procedures. This provides an opportunity to detect and address any potential issues or anomalies within that particular version of the SQL Stored Procedure. The following code provides an example on how to rename a SQL Stored Procedure for archiving purposes.
   EXEC sp_rename '[tddiscovery].[Delete_TaskMining_ActivityHistory]', '[Delete_TaskMining_ActivityHistory_2024-10-10_001]';
2. Execute the `Delete_TaskMining_ActivityHistory` Stored Procedure. This deletes all data related to Activity History for a cut-off timestamp from the `[AutomationSuite_Task_Mining].[tddiscovery].[ActivityHistory]` table.
## SQL Stored Procedure: Delete active history
:::important
Before executing the `PROCEDURE [tddiscovery].[Delete_TaskMining_ActivityHistory]` script, ensure that Task Mining usage is suspended.
:::note
Although there is no restriction on deleting data using a SQL Stored Procedure, it would be a good practice to retain the activity history in the system for a minimum period, for example, 30 days, to preserve recent activity records. This also provides an opportunity to detect and address any potential issues or anomalies within the SQL Stored Procedure before it is permanently deleted.
The following table describes the parameters for the `Delete_TaskMining_ActivityHistory` SQL Stored Procedure.
| **Parameter** | **Description** | **Mandatory Y/N** |
| `@CutoffTimeStamp` | Delete all data before a specified timestamp (e.g., **2021-01-01 01:00:05**).Do not provide a timestamp that leads to an empty table. | Y |
| `@BatchSize INT = 10000` | The number of rows to be deleted at a time. This enables you to delete the data batch by batch.`The default is set to 10000.` | N |
The following code provides an example of how to run the Stored Procedure.
DECLARE @ProcessTime datetime2;
SET @ProcessTime = '2024-07-11 13:44:42.7856026';
EXEC [tddiscovery].[Delete_TaskMining_ActivityHistory] @CutoffTimeStamp = @ProcessTime;
For more information, see the official Microsoft [documentation on Stored procedures](https://learn.microsoft.com/en-us/sql/relational-databases/stored-procedures/stored-procedures-database-engine?view=sql-server-ver15).
