# Performing node operations
> | Documentation | Description |
| [Adding a new node to the cluster](adding-a-node-to-the-cluster.md) | How to scale your deployment by adding additional nodes. |
| [Removing a node from the cluster](removing-a-node-from-the-cluster.md) | How to safely remove a node from the cluster on a multi-node HA-ready production setup. |
| [Repaving a cluster node](updating-cluster-nodes.md) | How to repave cluster nodes without any risks. |
| [Shutting down a node](starting-and-shutting-down-a-node.md) | How to perform a graceful node shutdown. |
| [Renaming a node](renaming-a-node.md) | Best practices for renaming nodes. |
| [Performing node maintenance](performing-node-maintenance.md) | What to do before and after a node maintenance operation, to ensure the cluster is healthy. |
:::important
RHEL kernel versions `kernel-4.18.0-372.91.1.el8_6` and `kernel-4.18.0-477.10.1.el8_8` are affected by [an issue](https://access.redhat.com/solutions/7014646) that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses these kernel versions either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libs
