# Get Specific Group
> Returns information about a group, based on the organization and group ID.
## API Endpoint
`GET` `https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}`
## Scopes
Requires the following scopes:
* PM.Group
* PM.Group.Read
## Request Headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described [here](authentication-methods.md).
## Path Parameters
| Path param | Data type | Description |
| `partitionGlobalId`(required) | String | The ID of the organization containing the desired group. |
| `groupID`(required) | String | The ID of the group you want to retrieve. |
## Responses
### 200 OK
The specified group information is returned.
## Example Request
Let's say you gathered all the information needed to build the API call.
* Your `{baseURL}` is: `https://{yourDomain}/{organizationName}/{tenantName}/`
* Your `{access_token}` is: `1234` (for length considerations).
* The `{partitionGlobalId}` is: `magic-7`
* The `{groupID}` is: `2512`
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Group/magic-7/2512' \
Here's the response body for a successful call:
    "id": "2512",
    "name": "Automation Developers",
    "displayName": "Automation Developers",
    "type": 0,
    "creationTime": "2021-10-19T14:25:01.6574988",
    "lastModificationTime": "2021-10-19T14:25:01.6574988",
    "members": [
            "objectType": "DirectoryUser",
            "firstName": "Albus",
            "lastName": "D",
            "jobTitle": "master",
            "companyName": "Hogwarts",
            "city": "London",
            "department": "magic",
            "displayName": "Albus D",
            "source": "local",
            "identifier": "1787ef38-5933-4f2c-a67a-9c22cdb8e6a2",
            "name": "albus",
            "email": "albus@hogwarts.com"
