- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
2.2510.4
2.2510.4 release notes for Automation Suite on OpenShift.
Release date: September 10, 2026
Reduced ArgoCD access requirements for bring-your-own ArgoCD
When you bring your own ArgoCD, the helm-credentials secret is now yours: uipathctl does not manage it and requires no access to it or to the ArgoCD namespace. The uipathadmin service account no longer needs a role or role binding for the secret or for reading the namespace - the only permission it retains there is managing ArgoCD Applications, which it already needed to deploy Automation Suite.
For details, refer to Installing and configuring the GitOps tool.
Bug fixes
- We fixed an issue that caused the
prune-telemetryCronJob to fail on deployments that authenticate to SQL Server using Azure AD (Entra ID) Managed Identity, Default Azure credential, or Workload Identity authentication. The issue occurred due to a missing dependency in theuipathcorecontainer image. - An issue caused IdP-initiated SAML sign-in to fail with an "Invalid return URL" error when a Start URL was configured on the identity provider (for example, Google Workspace). We fixed the issue.
- We fixed an issue that caused the prerequisite certificate validation to incorrectly require
alm.<fqdn>andmonitoring.<fqdn>to be present in the certificate's SAN, even when the corresponding components were excluded usingexclude_componentsininput.json. - We fixed an issue where, in HA environments, the Horizontal Pod Autoscaler and the ArgoCD application controller continuously fought over a workload's replica count, causing it to repeatedly scale up and down.
- We fixed an issue where Context Grounding ingestion failed in offline (air-gapped) environments. Previously, ingestion failed for every file type, and the reported error incorrectly indicated a problem with the file contents.
Known issues
Maestro instance management page rendering issue
If Insights is enabled on the customer cluster, the Maestro instance management page does not render all information correctly unless the global.insightsRtmEnabled global feature flag is also enabled.
To enable the flag, in ArgoCD, open the Maestro application, select Details, then the PARAMETERS tab, and search for the global.insightsRtmEnabled key. Set its overridden value to true, exit the tab, and wait for ArgoCD to sync. If ArgoCD does not sync automatically, select Sync in the Maestro application.
Kerberos authentication limitations
Kerberos-based authentication is not supported for the following products and services:
- Agent Hub
- Agents
- AI Trust Layer (LLM Gateway, LLM Observability, Context Grounding)
- Autopilot for Everyone
- Autopilot (A4D)
- Integration Service
- Maestro
- Semantic Proxy
- Solutions
- Studio Web
- TaaS
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
FIPS 140-2 support limitations
Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights. If you need to use Insights, you can deploy it on a dedicated non-FIPS node.
For details, refer to Security and compliance and How to deploy Insights in a FIPS-enabled cluster.
MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier
When upgrading to Automation Suite 2.2510.4, the MessageBus schema migration fails if the database was originally created on Automation Suite 2022.10.x or earlier, regardless of how many versions it has been upgraded through since. Databases originally created on Automation Suite 2023.x or later are not affected.
To check whether your database is affected, run the following query:
SELECT * FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
If the query returns any rows, delete them before upgrading:
DELETE FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.4.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ✅ New: 2.2510.4 | Action Center release notes |
| Agents | ✅ New: 2.2510.4 | Agents release notes |
| AI Center | ✅ New: 2.2510.4 | AI Center release notes |
| AI Computer Vision | ✅ New: 2.2510.4 | AI Computer Vision release notes |
| Apps | ✅ New: 2.2510.4 | Apps release notes |
| Automation Hub | ✅ New: 2.2510.4 | Automation Hub release notes |
| Automation Ops | ✅ New: 2.2510.4 | Automation Ops release notes |
| Autopilot for Everyone | ◆ Bundled: 2025.9.7 | N/A |
| Data Service | ✅ New: 2.2510.4 | Data Service release notes |
| Document Understanding | ✅ New: 2.2510.4 | Document Understanding AI Center-based projects release notes Document Understanding modern projects release notes |
| Healing Agent | ✅ New: 2.2510.4 | Healing Agent release notes |
| Insights | ✅ New: 2.2510.4 | Insights release notes |
| Integration Service | ✅ New: 2.2510.4 | Integration Service release notes |
| Maestro | ✅ New: 2.2510.4 | Maestro release notes |
| Orchestrator | ✅ New: 2.2510.5 | Orchestrator release notes |
| Process Mining | ✅ New: 2.2510.4 | Process Mining release notes |
| Screenplay | ✅ New: 2.2510.4 | Screenplay release notes |
| Solutions | ✅ New: 2.2510.4 | Solutions release notes |
| Studio Web | ✅ New: 2.2510.4 | Studio Web release notes |
| Test Manager | ✅ New: 2.2510.4 | Test Manager release notes |
- Reduced ArgoCD access requirements for bring-your-own ArgoCD
- Bug fixes
- Known issues
- Maestro instance management page rendering issue
- Kerberos authentication limitations
- FIPS 140-2 support limitations
- MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier
- Deprecation timeline
- Bundling details
- Product versions
