Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2.2510.0
      • 2.2510.0+patch2
    • 2.2510.1
    • 2.2510.3
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
    • 2.2510.3
2.2510.3
2.2510.3 release notes for Automation Suite on OpenShift.
Release date: July 23, 2026
Product sizing improvements​
We have optimized the minimum hardware requirements for Automation Suite products such as Integration Service and Document Understanding. To check the hardware requirements for deploying Automation Suite 2.2510.3, refer to the capacity planning calculator.
Installing Automation Suite without cluster-scoped permissions​
You can now install Automation Suite without granting the installer service account (uipathadmin) any cluster-scoped permissions (ClusterRole or ClusterRoleBinding). This flow uses namespace-scoped roles only, with a cluster administrator performing the compensating actions that require cluster-scoped access.
Configurable concurrency limit for Automation Suite Robots​
You can now explicitly define the maximum number of jobs that can run concurrently in Automation Suite Robots. Previously, Automation Suite Robots used get and list permissions on nodes to determine this limit, which are not available in clusters with strict RBAC policies.
To configure the maximum number of concurrent jobs, set concurrency_limit in the asrobots section of input.json. For details, refer to Automation Suite Robots-specific configuration.
Improved certificate validation error messages​
We have improved the error messages returned during prerequisite certificate validation. Checks now report the exact failure, such as incorrect chain order or certificates not belonging to the chain, instead of a generic message.
uipathctl improvements​
  • The uipathctl manifest apply --dry-run command no longer requires confirmation. Previously, running this command prompted for confirmation.
  • You can now use the --node flag with uipathctl prereq run to control which node runs the per-node prerequisite checks. Use --node any to run the checks on any available node without pinning to a specific node, --node <node-name> to run the checks only on that node, or --node all (default) to run the checks on every node, as before. For details, refer to uipathctl prereq run.
  • You can now configure CPU and memory requests and limits for workloads created by uipathctl, such as those used for health checks, prerequisite checks, support bundle generation, migrations, and upgrades. Use the workload_resources parameter in input.json, or the --probe-cpu and --probe-memory options for commands that support them. For details, refer to Configuring resource requests and limits for uipathctl-created workloads.
Romanian language support​
The Automation Suite user interface is now available in Romanian.
Bug fixes​
  • We have fixed an issue where Studio Desktop failed to load Integration Service connectors and activities due to a routing misconfiguration in the intsvcs-periodic VirtualService.
  • An issue caused the prerequisite checks command to incorrectly fail when Document Understanding modern projects was enabled and AI Center was disabled. We fixed the issue.
  • This release includes the fixes delivered in Automation Suite 2.2510.2+patch1.
  • This release includes the fixes delivered in Automation Suite 2.2510.2+patch2.
Known issues​
Horizontal Pod Autoscaler and ArgoCD scaling conflict in HA environments​
Erratum - added September 10, 2026: In HA environments, when load increases, the Horizontal Pod Autoscaler (HPA) scales the affected workloads up while the ArgoCD application controller scales them back down. This occurs due to ArgoCD treating the replica count defined in the Helm chart or manifest as the source of truth, causing the workloads to repeatedly scale up and down without stabilizing.
To address the issue, you must patch the argocd-cm ConfigMap in the <argocd> namespace so that ArgoCD ignores replica count differences:
kubectl -n <argocd> patch configmap argocd-cm --type merge -p \
  '{"data":{"resource.customizations.ignoreDifferences.argoproj.io_Rollout":"jsonPointers:\n- /spec/replicas\n"}}'
Reapply the command after every ArgoCD chart re-sync or Automation Suite upgrade, since both overwrite the ConfigMap and remove the patch.
Prerequisite checks fail due to missing alm and monitoring subdomains in certificate SAN​
Erratum - added September 10, 2026: An issue causes prerequisite checks to fail when installing Automation Suite with CA-issued certificates if the certificate's SAN does not include alm.<fqdn> and monitoring.<fqdn>, even when the corresponding components are excluded using exclude_components in input.json.
We fixed the issue in Automation Suite 2.2510.4.
prune-telemetry CronJob fails after upgrading to Automation Suite 2.2510.3​
Erratum - added September 10, 2026: After upgrading to Automation Suite 2.2510.3, the prune-telemetry CronJob in the uipath namespace fails on deployments that authenticate to SQL Server using Azure AD (Entra ID) Managed Identity, Default Azure credential, or Workload Identity authentication, with the following error:
Cannot find an authentication provider for 'ActiveDirectoryManagedIdentity'.
Install the 'Microsoft.Data.SqlClient.Extensions.Azure' NuGet package
to use Active Directory (Entra ID) authentication methods.
The issue occurs due to a missing dependency in the uipathcore container image. All CronJob retries fail with this error.
To address the issue, upgrade to Automation Suite 2.2510.4, or you can temporarily delete the failing CronJob:
kubectl delete cronjob prune-telemetry -n uipath
Maestro instance management page rendering issue​
Erratum - added July 24, 2026: If Insights is enabled on the customer cluster, the Maestro instance management page does not render all information correctly unless the global.insightsRtmEnabled global feature flag is also enabled.
To enable the flag, in ArgoCD, open the Maestro application, select Details, then the PARAMETERS tab, and search for the global.insightsRtmEnabled key. Set its overridden value to true, exit the tab, and wait for ArgoCD to sync. If ArgoCD does not sync automatically, select Sync in the Maestro application.
Kerberos authentication limitations​
Kerberos-based authentication is not supported for the following products and services:
  • Agent Hub
  • Agents
  • AI Trust Layer (LLM Gateway, LLM Observability, Context Grounding)
  • Autopilot for Everyone
  • Autopilot (A4D)
  • Integration Service
  • Maestro
  • Semantic Proxy
  • Solutions
  • Studio Web
  • TaaS
We are working on bringing Kerberos support to upcoming Automation Suite releases.
Meanwhile, you can use alternative authentication mechanisms such as basic authentication or workload identity-based authentication.
FIPS 140-2 support limitations​
Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights. If you need to use Insights, you can deploy it on a dedicated non-FIPS node.
MessageBus schema migration fails on databases seeded from Automation Suite 2022.10.x or earlier​
When upgrading to Automation Suite 2.2510.3, the MessageBus schema migration fails if the database was originally created on Automation Suite 2022.10.x or earlier, regardless of how many versions it has been upgraded through since. Databases originally created on Automation Suite 2023.x or later are not affected.
To check whether your database is affected, run the following query:
SELECT * FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
If the query returns any rows, delete them before upgrading:
DELETE FROM [msgbus].[__EFMigrationsHistory] WHERE MigrationId NOT LIKE '2[0-9][0-9][0-9]%'
Context Grounding ingestion fails in offline environments​
Erratum - added September 10, 2026: In offline (air-gapped) deployments, Context Grounding document ingestion fails for every file type. The reported error incorrectly indicates a problem with the file contents.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.3.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center✅ New: 2.2510.3Action Center release notes
Agents✅ New: 2.2510.3Agents release notes
AI Center✅ New: 2.2510.3AI Center release notes
AI Computer Vision✅ New: 2.2510.3AI Computer Vision release notes
Apps✅ New: 2.2510.3Apps release notes
Automation Hub✅ New: 2.2510.3Automation Hub release notes
Automation Ops✅ New: 2.2510.3Automation Ops release notes
Autopilot for Everyone✅ New: 2025.9.7Autopilot for Everyone release notes
Data Service✅ New: 2.2510.3Data Service release notes
Document Understanding✅ New: 2.2510.3Document Understanding AI Center-based projects release notes
Document Understanding modern projects release notes
Healing Agent✅ New: 2.2510.3Healing Agent release notes
Insights✅ New: 2.2510.3Insights release notes
Integration Service✅ New: 2.2510.3Integration Service release notes
Maestro✅ New: 2.2510.3Maestro release notes
Orchestrator✅ New: 2.2510.4Orchestrator release notes
Process Mining✅ New: 2.2510.3Process Mining release notes
Screenplay✅ New: 2.2510.3Screenplay release notes
Solutions✅ New: 2.2510.3Solutions release notes
Studio Web✅ New: 2.2510.3Studio Web release notes
Test Manager✅ New: 2.2510.3Test Manager release notes
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
