- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
- 2.2510.2+patch1
- 2.2510.2+patch2
Automation Suite release notes
Release date: June 2, 2026
About this patch
This release applies a patch to Automation Suite 2.2510.2. The patch addresses some issues in Automation Hub, Document Understanding, and Maestro. For more details, refer to the individual product release notes referenced in the Product versions section.
This patch also includes the following fixes:
- We have fixed an issue related to Semantic Proxy where installation fails in lite mode. The issue occurred due to the semantic proxy container using incorrect CPU/memory resources.
- We have fixed an issue related to Autopilot (A4D) where installation fails in offline environments. The issue occurred due to Autopilot attempting to access a public API that is not permitted in offline setups.
These fixes will also be included in all future releases starting with Automation Suite 2.2510.3.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2.2510.2+patch2.
Legend
✅ - This Automation Suite version bundles a new version of the product. New release notes are available.
❌ - This Automation Suite version bundles a previously released version of the product. No new release notes are available.
| Product | Product version | Release status | Release notes |
| Action Center | N/A | ❌ | N/A |
| Agents | N/A | ❌ | N/A |
| AI Center | N/A | ❌ | N/A |
| AI Computer Vision | N/A | ❌ | N/A |
| Apps | N/A | ❌ | N/A |
| Automation Hub | 2.2510.2-patch2 | ✅ | Automation Hub release notes |
| Automation Ops | N/A | ❌ | N/A |
| Autopilot for Everyone | N/A | ❌ | N/A |
| Data Service | N/A | ❌ | N/A |
| Document Understanding | 2.2510.2-patch2 | ✅ | Document Understanding modern projects release notes |
| Healing Agent | N/A | ❌ | N/A |
| Insights | N/A | ❌ | N/A |
| Integration Service | N/A | ❌ | N/A |
| Maestro | 2.2510.2-patch2 | ✅ | Maestro release notes |
| Screenplay | N/A | ❌ | N/A |
| Orchestrator | N/A | ❌ | N/A |
| Solutions | N/A | ❌ | N/A |
| Process Mining | N/A | ❌ | N/A |
| Studio Web | N/A | ❌ | N/A |
| Test Manager | N/A | ❌ | N/A |
